Power steering HELP
I screwed up my mini truck power steering box ...It always want to turn left (wheel counter clockwise) when you let go. With the pitman arm off it goes full lock left spinning the wheel fast!
Here is what I did: Trying to shorten steering colum I cut the end of the input shaft off on the box. BIG MISTAKE It is hollow (a swedged plug usally is in the end) so when I started it up fluid spit out the end. I welded the end and it no longer leaks but now it want to tun left. I tried purging starting full left and full right....same results.
Did I wreck the box?
It has a internal leak.... need to do a complete reseal...
$75 for a used box from an 84 fixed the problem. I figured this was cheaper than a rebuild. Another lesson learned!
Nocents
