Power Steering/Future SOA question
I want to install power steering on my 72 FJ40. In the future, I plan to go SOA. Will I be doubling up/wasting parts and money by doing the power steering now and then at a later time doing SOA and Hy Steer?
I know the best way would be to do it all at once. I just finished front disc brakes and am currently installing a Metal Tech family cage. I have limited time to do my mods so I like to finish some so I can ride before I break it down again.
Any help is always appreciated.
Go ahead and do the powersteering now. About the only part you will have to replace is the tierod from the pitman arm to the passanger side steering arm when you upgrade to highsteer and go SOA. I would go Saginaw since you want to go SOA you will be running big tires and the minitruck steering does not like to turn much over 35s wheeling.
John Smith said:
Go ahead and do the powersteering now. About the only part you will have to replace is the tierod from the pitman arm to the passanger side steering arm when you upgrade to highsteer and go SOA. I would go Saginaw since you want to go SOA you will be running big tires and the minitruck steeting does not like to turn much over 35s wheeling.
X2. Well put:cool:
Andy,
Here are the links I mentioned Sunday. I originally bought a AA kit and returned it because it had a non-collapsible steering shaft. I replaced it with a kit from Downey. This was in 2000 so they may have changed since then. If I were to do it again I would piece my own kit together because at times want a combination of parts that don't come in a 'kit', I like beating the system and I am a cheap bastard. I did my RDB for around $125. The other reason I would not go with one of these kits is because they both came with the crappy cast iron mounting braket for the Sag box. This limits the possiblities on how you mount your box and in most people's opinion puts it in a fawked up place. Since I did mine I have seen some really cool arrangements and the one I like the best is made by Lance Williams (lwilliams@cov.com) rocklobster somethingortheother. I believe his shop is in VA but am sure others could provide petter contact info or a link.
I had a nightmare finding a place that would make my hoses. I finally found Birmingham Hose Shop down by Craneworks and he set me right up, abeit not inexpensively.
X3 on what others have said. You need to decide if you want to go Hi-steer or X-over steering. If the latter you can prolly find someone willing to sell their old double arm http://www.aqualu.com/landcruiser/details.asp?Id=57. cheaply as Hi-steer is now the rage because it protects the tie rod from rocks. I have no experience with but many rave about Luke's steering setup as it puts the TR behind the axle for ultimate protection. I have heard there can be interference when the front axle is cut and turned but I am sure there is a remedy. See http://4x4labs.com/products/steeringarms.html. Don't forget about www.marlincrawler.com
here are some other good links I have saved over time:
http://www.flamingriver.com/index.cfm
http://www.ottindustries.com/
http://www.pirate4x4.com/forum/showthread.php?t=307120&highlight=saginaw
I am sure someone makes a bracket for the PS pump that will bolt up to your F-motor. Good luck.
Hey, you gonna sign up for ROTW once we get that cage done?
You wouldn't recognize it! I can spend money faster than anyone other than my wife.
You'd have to help me find a job when I was done because I would work on it all day and not do my day job!
Do you have all/most/some of the bars fit/notched? Got the outlaws in town this weekend so may be able to slip over for a little while.
