Power steering disappeared randomly
Jefferson City TN
hey guys,
Driving home today my power steering literally disappeared.
It was a hot drive, but I see no signs of leaking. What could cause this?
I leave for a cross country trip in the morning so I am trying to get it fixed asap...
Any help would be great
Not sure what is in it. It is low bottom side line on hot, but not empty
Yelowish fluid so I would guess power steering.
I have not changed it since owning it
If I rev the motor it kinda gets easier, but not really
It appears to be, haven't messed with it.
I just got back from Michigan, then today did 8 hrs round trip on road to NC.
It was find earlier today and now nothing. If I rev to 2k it makes it easier. I cannot hear the power steering trying at all at idle. No noise and can't move the wheel without great effort.
So I have added almost 10oz of PSF(what it had in it) and cycle it and it seems to still need more. It fills but then slowly drains.
No improvement on steering
If you don't see an obvious leak from the pump, hoses, or steering box, then the fluid is probably leaking from the input/drive side into the crankcase. Check your oil level to see if it is rising instead of staying level or slightly getting lower, as most engines do consume at least a wee bit of motor oil.
Oil level is about normal. Changed it yesterday and was less than 1/2q low for 3900 miles.
So how bad is a pump to swap? I think it ran dry and I am not sure fluid is going to fix it
Swap is easy and rebuild is a bit harder. You need to figure out where that much fluid is going. It would leave a hell of a stain in your driveway. If you dang fix the leak then it will run low/out again even with a fresh pump.
That is a lot of fluid, it has to be going somewhere, if not on the ground, it's going into the crankcase, front pump seal shot.
Front pump seal was done at a shop recently. Maybe they didn't fill it back up?
Got a pump on order, will see about getting it swapped.
It's a hydraulic system, so wont work without fluid. From the cheap seats this is confusing, at about an ounce or two low, it should start groaning, sucking air, most would stop and leak check, refill. No mention of noise? 10oz is a lot, like half of the system capacity, well past the minimum needed to work. That much fluid coming out in a short time will make a big mess, no mess leaves only one conclusion, it's leaking into the crankcase.
x2 for leaking into the crankcase.
I dealt with this a while back. The pump would groan and I'd fill it up and it'd groan again and no puddles on the ground. I cheaped out and just replaced the o-ring between the pump and the block. No joy. Replaced the pump, all good. Now I have a spare to rebuild some day.
In my case it was not random, but after doing lots of donuts in deep snow. :meh:
I've seen pump failure due to old fluid. Contaminants can develop in the oil and then interfere with the vanes sliding in the pump. The vanes get stuck in the compressed position and then won't pump fluid.
I do a complete flush with clean ATF and then drive the truck. It might take a while for the clean fluid to get the vanes free. Once the pump comes back to life flush the system again.
Have done a bunch of pumps and boxes, seen them way full of goo, screens clogged, etc, never seen the vanes stuck down from perished fluid, could happen but wouldn't call it common. Have seen them stuck from running dry, burning the pump up, but that is normally associated with noise?
The PO testifies that the pump seal was recently changed, don't see how that could be done without taking the pump apart? With it apart, at least some cleaning would be done? One would think that the old fluid wouldn't be retained, when it was put back together new fluid would be used? Also mentioned that the fluid is "Yelowish" the badly contaminated systems that I have worked on, had black or at least dark grayish fluid?
Something I mentioned a few weeks back on MUD, there is on (at least European models) there is a variable assistance valve on the steering box, these can get stuck and give poor assistance at were revs, yours seems to be the reverse? So go with the flush advice first, I would repeat and see if anything alters. The variable valve definitely responds to clean fluid, also the Yellowish fluid, perhaps an addivie?
Regards
Dave
Got it fixed.
Tried a drain and fill, no luck. So replaced the pump and new fluid and it is working wonderfully. With 302k it was time I guess. I have kept parts for spares/ rebuild. We are now in Amarillo heading to Colorado from east TN. Thanks for the help guys. I followed a lot of suggestions but sadly I think the pump was ran dry and air locked. Bleeding and new fluid didn't help.
