Power steering disappeared randomly
Glad to hear your steering is back.
You may want to do an oil & filter change sooner than later. If that much hydraulic fluid made it into the crankcase, it could lower the oil viscosity and cause premature wear. Maybe I'm being overcautious, but that's my two cents.
If you come through Durango you can use my tools and carport in exchange for :beer:.
Pulled into camp and checked fluids... power steering was almost gone, no visible leak. Guess the seal to the block is way bad now.
Any chance someone has some pics/ video. Going to try and just keep an eye on it and then when I get home I will repair it.
Did you replace that seal when you installed the new pump? IIRC it's just a big o-ring.
What does your engine oil dipstick register after the engine has been off for 15 minutes?
I'm serious about the offer to use tools and a carport in Durango, CO. You have a lot of miles between you and home, and the idea of you losing power steering while wheeling the mountain passes with kiddos on board is not a savory thought.
My pump came with a small o-ring, a woodruff key and a set of washers. No big O ring that I saw
Do you have a link to which seal? I can tell you what I replaced...
Engine oil registers about normal, it is hot here in NM but after sitting for about an hour it was on the hot F line
The big O ring seal only seals the pump body to the engine block and it keeps engine oil from leaking out. If PS fluid is leaking into the engine, it is leaking at the small seal on the input shaft. Repair/replacement requires basically rebuilding the pump.
It is a brand new pump
Would anything else cause a brand new pump to be almost dry after 1700 miles?
Pulled into camp and checked fluids... power steering was almost gone, no visible leak. Guess the seal to the block is way bad now. ...
The seal that can (rarely) leak into the block, is in the pump, a replacement pump should have a new seal. The chances of two pumps leaking into the block is slim, very rarely see this once, let alone twice.
If it is low, it wasn't full, had air trapped in it, or is leaking. Other than leaking into the block, there isn't really anywhere else it can hide, the leak should be visible. Have you looked it over carefully? If they have never been replaced, the return lines become brittle, known to crack/leak. Where they go down towards the cooler, under the battery, inside the frame from the steering box, is somewhat hard to see and a common leak point.
Thanks, will begin the search for leaks.
Thank you, @inkpot, for the clarification.
@TEC3, you did replace the PS pump, yes? I'm out of suggestions. Where is the fluid going if it's not leaking externally and not going into the crankcase?
Been parked on a clean dry surface for many hours... zero leaking. I can see a little bit of spotting near the fill cap, but it isn't leaking there. I have wiped both lines from reservoir to pump and ran the truck, turned and turned it. And the fluid level does go down a little bit nothing I would consider dangerously low like I found pulling into camp.
I am at a loss, what is it's total capacity? Is their a trick to bleeding the lines that I could be missing?
When I changed the lines and bled mine, I had the front on jack stands and with the engine OFF, I went SLOWLY left to right lock about 100 times. Had to refill about every 10 cycles.
Then I started it and did the SAME thing SLOWLY. I would refill about every 10 cycles.
Don't know if you're using PS fluid or Dexron 3 as called out.
Not sure how MUCH it took, it was just a LOT of cycling SLOWLY, but I never had to add more.
