Power Steering Cost
Sedro Woolley, Wa.
Just bought a 75FJ that was supposed to have power steering but doesn't. Need to go back on the seller. What would be the cost for this installation parts and labor? Help!
Bill
85FJ60 in progress
75FJ40
Factory power steering wasn't avalable till 79 IIRC but you can get a FJ box and pump for around $700-$800 that may bolt right on (some of the early F2s don't have the bolt holes for the pump). A saganaw setup is more fab work but is considered by most to be a better setup. $1200 is probably a fair ball park price.
Kevin
Mini Truck PS gear box 50.00
Reman GM pump 50.00
Bill Dorry's Box/pump mounts 180.00
High pressure hose 20.00
Volvo pulley 5.00
Belt 10.00
So roughly $315, with you doing the labor
GL
Ed
The best I can add up, I have about $392.00 and I have hydro assist.
$50 saginaw junkyard box 1992 Chevy 2wd pickup
$10 pillow block
$20 napa u joint and yokes
$60 Borgeson u joint
$40 borgeson slip shaft
$22 hydraulic lines for hydro assist
$70 ram
$50 high pressure line for saginaw box
$40 PS pump
$30.00 in scrap steel/bolts
Turns 44" boggers with the front spider gears welded.
JR
