Power Button
The power button greatly improves drivability, especially with 35" tires. Are there any disadvantages to leaving the power button engaged all the time?
Wear and tear on the tranny? Reduced mpg?
The power button only changes the mapping for the shift points. It raises the rpm numbers by 20% ? or so. It does not create any more power from the engine. You can accomplish the same thing, or more, but grabbing the shifter and running thru the gears like a teenager on Saturday night! No more power, but a lot more fun!! John
I recently "rediscovered" my power button and it does make a difference! I must have accidentally turned it off when installing a switch or cleaning the dash. I thought my engine was starting to go (thinking head gasket, loss of compression, etc) because it felt so sluggish. This had been going on for a week or two until I realized the "ECT" light was not on. Flicked the switch and it was back to normal. Having an extra 20% of RPMs before shifting to the next gear is a must with 37s...even with 5:29 gears
I have 33's and my truck jumps off the line quite nicely, which is the only time it doesn't feel underpowered. I use the button for launching into fast moving traffic, but I have to say that it doesn't do all that much.
I think I read in another thread that using the PWR button also changes the RPM where the torque converter locks up.
Yes I read that also on mud.
That would be considered as another "shift point"
