Power Bleeder Brake Bleed Kit
The Motive universal adapter works, but be careful because it can blow brake fluid all over the place if it isn't sealed (ask me how I know...).
The Cruiser is tough to adapt to because the cap for the reservoir doesn't thread on.
I guess I'll give it a shot. Appears as thought the 1.9" adapter should work? Plan on replacing master cylinder next week so I'll let you know what pressure I use and adapter that works.
Throw a towel over the master in case it blows off. It sucks getting brake fluid on your paint job.
You are aware that the master cylinder comes with its own build-in pressure bleeder? It develops 20 times the pressure as one of the add on pieces and you don't risk blowing brake fluid all over. With this pressure bleeder you can have the job done before you get the expensive bleeder set up.
Pin_Head - I was not aware of that. Will have to look into it when I get the new master cylinder I ordered. Thanks
Motives can be great or can be a messy nightmare. I like them, as long as the hoses and fittings are good they don't leak. for the LC, I use the universal cap and instead of using the little chain it comes with, I use a strong (or two) zip ties to connect to the J bolts on the bottom. 20 psi and no problems. The chain can leak so I stopped using it.
Yes! It is called your foot and with it on the brake pedal you can easily pressurize the system to 500 PSI or more. It uses the 2 person bleeding method and the key points to properly using it are to pressurize the system before opening the bleeder to compress any bubbles and to close the bleeder while fluid is still coming out and before you let up on the pedal to make sure that no bubbles get sucked back into the system. The best thing is that it only takes about 5 minutes to bleed the entire system and it even works on the most stubborn bubbles as long as you do it properly.
Ha! That I was aware of. Done that before. I am most likely doing this project during some time off from work and will be solo. If I could train my dogs to help, that would be awesome. ;-)
I use the universal mount without issue, 10psi does the job plenty quick.
I would never go back to bleeding the old fashioned way FWIW. Pressure bleeder is a lot faster.
Not that expensive either all things considered. Only need one pump/reservoir and then different adapters depending on what vehicle you're using it for.
I built an adapter head for my shop compressor with random parts at the hardware store for about $10. IIRC a plastic cable pulley, two drywall anchors, and a bit of chain. Gasket sheet, 1/4 nylon air hose, 1/8npt to 1/4 tube connector, and the QD fittings all lying around the garage. My shop gauge doesnt really even go low enough.. I just give it enough pressure to hear the hiss through the regulator a bit.. and bleed them. Solo works great.
^^^^^^^^ Same. Universal adaptor, 15 psi max or mine starts leaking. LSPV is the hardest thing to bleed on mine.
no one here do gravity bleed .. that's my best way, one man, less stress easy way to do it..
I use gravity for flushing.. but pressure bleeding when installing a new component or dealing with air in the system otherwise.
Ii do gravity bleeding always .. and so far seems to work better in all cases than pressure bleeding ( not better or faster than the 2 folks method .. but I hate asking for favors ..
I gravity bleed before power bleeding, but gravity bleeding alone... often will not remove air from the LSPV, you need a good amount of fluid under pressure to move air trapped there.
