Possible rear main leak?
Logan Utah
So I have putting off tracking down some oil leaks... I think I may be leaking from the rear main
There are crusties around the seal/crank interface and I think a small amount of oil.
It was tough holding a light, mirror and camera, sorry for the poor angles..
Thoughts?
222222 miles..
oil pan, side cover and valve cover leaks can look like rear mains. I suggest to eliminate those possibilities, clean the motor off, and drive it a while to see if it is still leaking back there...rear main is a bear.
Put a diaper on it, pour in more oil, and run it.
Pan arch leaks are more common than the rear main.
If that's a leak I don't want to know what you'd call my leaks... :meh:
I laughed when a friend of mine said he had to find his leak because it was making about 1 drip a month!!! Mine leaks that each day!
seriously if that is a leak i would focus on other stuff. When were your berfeilds rebuild or your bake lines replaced?
But i do understand. I had a few leaks with some old oil accumulation on the front of the engine. I replaced valve cover, spark plug gaskets, distributor o ring and few others. It all stopped up top but i was still using a little oil and wet down low. A little wet up front and just a touch in the back. I did the oil pump seal and i am better up front but still a little wet near the power steering pump. today i saw a little oil near the rear seal. Honestly if it is just a few drops i am not going to bother with it. Mostly i want to know where i am leaking from so i can assess the cost/work of repair vs. the severity of leak.
Glad to find this post today as I started to research the topic. My truck was on a hoist this afternoon at Tru-Line as we were trying to find the source of leaks that is drenching the front of the undercarriage. While at it, we saw a small drip hanging around the rear main seal area. It wasn't dripping, just a small buildup hanging there. But the shop manager told me that it may not be the source of a leak and does not need attention yet. It is a bit messy there, so I think the small buildup could be from oil that was blowing on it from other leaks at speed. So, the plan is to take care of the obvious and major leaks first (front main seal, primarily), clean up the area thoroughly of residual oil and grime, and then check what it looks like near the rear main seal after a week or two of driving. Will keep my fingers crossed that I find it dry and clean.
Hope yours is the same thing, mderrick.
Probably the upper arch sealing.
Spray areas with Super Clean Degreaser:
http://liftslubeandmore.com/web_images/degreaser_32oz_hero.jpg
an then spray off at a self service car wash. Now all the areas are "Super Clean" and you can easily monitor for the leak source(s). This product will do wonders on your engine bay and spots on your concrete as well.
