- Thread starter
- #21
It's a good thought but the entire length of the exhaust system is tight. The noise is more of a binding then releasing "pop!" type of sound, not a tinging metal sound, if that helps. That's the best way I can describe it.
For about year I had a weird ping/pop (sometimes multiple) whenever I accelerated. It finally turned out to be a loose bolt on my motor mount! The nut was about to fall off the threads of the bolt.
HTH
Interesting. It's not the skid plate but I did look the transmission cross member over quite a bit and even re-torqued all of the bolts. Was your's pretty loose?
