Poll: What to do about bent frame?
  • 1) Take it to frame shop. $$$$
    Votes: 9 75.0%
  • 2) Yank it "straight" with backhoe
    Votes: 1 8.3%
  • 3) Cut and paste "washer mod" on frame brackets
    Votes: 1 8.3%
  • 4) Build custom offset drop brackets
    Votes: 1 8.3%
  • Total voters
    12
Beech Bluff, Tennessee
A little background. When I bought my '92 a few years ago, it had been wrecked on the front left corner. Damage didn't look too bad. Bumper was toast. Fender was repairable. Headlight tabs broken. Other than that it seemed fine. It sat parked at my dad's farm for a couple years until I finally brought it home and started working on it a couple months ago.
After installing my OME lift yesterday, I noticed something I had not before. It seemed like the right side of front axle was further forward than the left. Turns out the right front tire is about 7/8" further from the rear tire than the left. I got under there and cross measured from the rear control arm brackets to the front and it is not square. FML. Frame is apparently bent. It must have taken a lot harder lick than it looked like.
My budget for the build is getting pretty tight for a while since I just purchased the OME lift.
So my options are:
1) Take it to a real shop and have them put it on a frame machine. Upside is it should be done right if they know what they are doing. Downside is it will be expensive. Most likely more than I really need to spend on it now.
2) Chain the right rear corner of frame to a tree and front left corner to my backhoe boom and pull until it measures square. I've actually done this before on an S10 with good results, but the S10 frame was lighter and truck not worth much so I really had nothing to loose. Upside is it won't cost me anything. Downside is I could possibly do more damage.
3) Get out the fire wrench and welder and do the "washer mod" on my control arm brackets, setting the right side back and left side forward, to square the axles. Upside is it would be simplest and cheapest option. Downside is permanent modification of frame brackets.
4) Build custom offset drop brackets for my front control arms that will square the axles. Upside is I already need to correct caster since installing lift, so would kill two birds with one stone. Also would be no permanent modification. Could put it on frame machine at a later date when finances allow. Downside is.. well I'm not sure.
I'm leaning toward option 4 for now. Looks like having my cake and eating it too. I could correct the alignment problem for now, but could always remove and replace the brackets and have it done right at a later date.
So, what say the hive?
Get quotes from a shop for squaring the frame so you know exactly how much it will cost. Upside is that quotes are free. Downside is that you'll spend money in gas driving to a dozen different shops.
Take it to a shop. In the long run - if you are keeping your LC - will save you a lot of problems down the road.
Another option - keep an eye out for a donor truck. Blown engine, flood damaged...etc - with a good frame. With all the flooding in Texas this year - there has to be some available.
Good luck.
:popcorn:
My experience is that frame shops are not that expensive. They straightened the front axle housing on my Suurban for $100 which took about 2 hours to do.
^^ I hit a bull moose with one of my welding trucks (65mph) and bent the frame on the F-PS corner. 500$ and 3 days later it was straightened, realigned and back on the road.
J
Frame shop, unless you have the right equipment and experience you are only going to make it worse. It's not just the bend, it's also the stress involved in bending it both ways.
Option 1 and then option 4. I'd try to straighten frame first but obviously you're familiar with squaring axles to eachother and thats the most important.
Obvioisly if you go option 1 I'd still cross measure axle to axle.
I'd just try to fix it the right way first... Unless it's $$$$
We just bent back my buddies 95 toy p/u. Couple hours on the frame rack is all it took, and it was bent bad.
Option 1 unless it's entirely too much for your wallet to handle. Otherwise I would go with a combo of 2 and 4.
honestly then why even fix it? if it is just a trail truck i would leave it alone.
Because now that I know it isn't right, I see it every time I look at it. It really sets off my OCD. And I will drive it on the road locally some. Have curbs to climb at the mall and such. Just not planning to make any trips 85 mph on the interstate.
ETA: See. I had to edit my post because I forgot to capitalize an "I".
