Please help, major electrical issuses
Ambridge, PA
I am having some major electrical gremlins and am in desperate need for some help. Here is the what and when of what has been going on. I would like to know if any of this could be related, or if it’s just my dumb luck.
•A few weeks ago my rear diff lock indicator lamp would come on intermittently and very faintly while driving. I went wheeling and after I got done and unlocked it the problem went away. Weird, but whatever.
•On my way back from a long trip the Sunday after Christmas my rear wiper started to wipe on its own from time to time. I think it’s the control box under the trim on the inside of the lift gate, but it’s just unplugged for now.
•My ABS went aloof the other day (I think it’s just the sensors needing cleaned, just pulled the fuse for now). But I happened to notice that when I was on the brakes gently, like if I were coming to a gentle stop, and turned on the marker lights (not the headlights, just the markers) I could feel a slight, but definite pulse in the brake pedal. As if the second I would turn on the marker lights I would hit a very little patch of ice. Again, weird.
•This morning my rear diff indicator light came on again, this time very bright, about as bright as when it comes on for real. It would flicker and flutter from time to time but remained on.
•A few seconds after brainstorming what that could be, I noticed that every time I pushed in the brakes my interior lights would come on as if the marker lights had been turned on. I got out and wedged the brake pedal down and noticed that all of my marker lights would come on every time the petal is depressed.
Could the ABS issue and the marker lights be related? I’m not very good with electrical systems AT ALL. I am also a bit confused as to where the relays and controls for the ABS, the lights, and the wipers?
If you took the time to read all that, thank you so much!!
Shane
Sounds like a grounding issue to me. I'm no pro on the electrical systems in 80's, but I am an Electrician. I can tell you that when things lose grounds, often times they try to ground via other systems or wires and can "backfeed" thus giving you the weird lights on half dim...ect.
Now if someone can chime in on the common places for grounds to come loose...
I will do so, thank you very much for the sugestions, I have ruined a few cars in the past because I have neglected to repair electrical components, this gives me more confidence that it may not be a short, but simply a ground.
Corbet, where exactly have others had issues with the wireing through the firewall? The grounds, or frayed wires, etc? Sorry for the dumb questions, I can diagnose and fix mechanical problems quite well, electrical ones are another story.
Oh and I added a second battery using 2/0 welding cable, but have only grounded it to the starting battery. Should I upgrade the grounds? Ground the second battery to the chassis and block?
Sounds like you have no real ground for your second battery but Yes and Yes to the other two questions. Also, I would disconnect the second battery while you are trouble shooting.
Did the problems start right after adding the second battery, or has the battery been there for awhile? I grounded my second battery to the frame. I don't have the FSM but if someone here may have the wiring diagram that shows all of the grounds that would help you track them all down.
No the second battery has been in for a while, the electrical system just started giving me problems. I grounded the second battery to the first one because that's what I have read to be correct, but more grounds I'm sure won't hurt
I would love a wireing diagram of all the grounds, does anyone have one?
Most devices are grounded directly to the chassis sheet metal. Sometimes there is a separate ground wire and on Toyotas, this is a white wire with a black stripe. A "floating" ground is often the cause of the brake/marker light problem you describe. You can test for a bad ground by temporarily running a ground wire from the lamp housing to the chassis and see if the problem goes away. You can also use a test probe for this test and if it lights up, you have a bad ground that you need to fix.
So you are implying that the problem resides in the brake light ground? I will look into this in more detail after work. Thank you for the info!!!
I am so lost with electrics, I was thinking of taking all the chassis grounds and running them to a larger gauge wire running the entire length of the vehicle directly to the battery. Is this a bad idea?
I tried a quick search for a pic for you but came up empty. But there an area below and somewhat in front of the FHH (firewall heater hoses) and next to the EGR system that others have had melt/burn the wiring harness. With the number or circuits in that section I would imagine any number of gremlins could appear.
Its most definatly a ground issue or even something +12v getting intermittantly grounded.
Check the ground strap from the battery to the body. A single or pair of little 10mm bolts on a primary ground is crazy.
Then check to make sure the straps on the engine are tight to the body. Mine had 3 straps to the 1FZ
Also check your email
Try wiggling the wire harness that goes from the body to the upper hatch, if there is a short there, I have had the brake lights/rear wiper and interior lights act weird. If that is the case, the rear locker may just be a different/unrelated problem.
Thank you very much for all the help, I will keep posted on what I find.
I had similar, weird, random powering of electrical devices in my FJ55 a few years back. I found that, while the major ground wires to the block, chassis, and body were all tight, there was some oxidation between the wires and the metal. I'd recommend disconnecting and cleaning all of your main ground connections. with all of the random stuff you have being back fed power I'll bet you will find something along those lines to be the problem.
On my FJ55 the main problem was the grounding of the body of the voltage regulator to the body. It allowed the backfeeding of power to my coil which made the engine keep running with the key turned off.
Update:
I removed the ground under the tailgate and cleaned the contact points and replaced it, nothing. I also removed the locker plugs, inspected them and replaced them, nothing the light remained on, even with these unplugged.
I noticed that when locking it with the factory keyless that the high mount brake light comes on with the marker lights when they flash. So I think this means that the marker lights and brake lights are somehow shorted together. But the brake lights don’t come on when the marker lights are just turned on. I’m so confused?
I don’t understand how the brake lights trigger the marker lights but the marker lights don’t trigger the brake lights, only when locking or unlocking with the keyless.
Also, this morning when I got in it and started it the locker light was not on for a few seconds, then came on, varied in dimness for some time and upon backing out of my driveway shut off. It didn’t come on again for the remainder of the 45 min ride to work, but the other problems still exist. So it seems that they are indeed unrelated.
I just wanted to give as much information as possible because maybe someone can help. I will check the rest of the grounds and the taillights when I can (I was freezing my butt off outside last night in the snow).
Thank you,
Shane
Shane, I dont know about the factory alarm in the 80 since mine doesnt work. But if I read this right, what im thinking is... when I arm the wifes lex the parking lights all flash including the high mount. Dont know if thats whats going on with yours.
Have you checked the battery terminals for corrosion. Check the terminal where the +12v goes into the fuse box. Check the +12v on the starter. After emailing you my story about the alternator, perhaps have that checked as well.
Do you have a multimeter ? you can check to see what the draw is on the parking lights when you depress the brake pedal.
James,
My terminals are all very clean, when I lock my truck with the remote the parking lights "were" the only things that flashed. Untill this problem, now the brake lights flash with the parking lights. I am thinking that it is something in or around my tail lights, but I will be sure to check my alternator, which is only about 6 mo old and all of my grounding locations, as well as my brake light wiring. After searching about every key word I found someone with the same problem, but they didn't post the solution, so I PM'ed them and am waiting on a reply.
Thank you for all your help.
Shane
The Gremlin has been caught!!!!
As it turns out, plug BQ1 which is behind the right rear interior panel under the jack mount was the culprit. Pins 3 and 4 were very corroded and shorting out with one another. So for the mean time(untill I get back from vacation) I just jumped the wires around the plug and presto, all was good. It took forever to figure out as I’m not very good with electronics.
Thanks to everyone for helping, I really appreciate all the response.
Shane
