Very nice writeup Cole. Good job...inspired me to work on my rig.
. i got the whole ride on video, but im still in the process of editingCole - Have you lowered your rear bump stops, yet? Any updates on rubbing/wear on front/rear tires? Anything new to report on the mods after living with them for another month or so? I'm going to need tires before winter and my shocks need to be replaced, so I'm inching towards the lift - probably later this summer. I really love the look of those 35" Toyos, though I don't know if I'll go that big since I won't be able to get the rig in the garage anymore if I do. We get a fair amount of snow up North and it's a PITA if you can't park inside. Thanks for your feedback and for being the guinea pig on this setup. Real
Cole, are your lug nuts tapered on one side and conical on the other side? Or is one side flat?
Your wheel adapters, like mine, require tapered lug nuts to match the tapered mating surface. So, the tapered side of the lug nuts should be facing in, not out.
good catch. ill have to go check that out. that seems like an obvious thing for me to miss but now you got me thinking and double checking myself. thanks for pointing that outThis maybe a stupid question, but I want to run toyo open country M/T 35's on my 2000 LC. I have already installed, 2 x OME865 Rear Coil Springs, 2 x Old Man Emu N133 Shocks, 2 x Old Man Emu N101 Shocks, 2 x Old Man Emu Torsion Bars and a slee diff drop. I run right now the stock mich. on the stock rims. From what I can tell now, would need, 1 inch wheel spaces, which I can get from motor-tech sports. With what I have so far, is there anything else that is needed, other then maybe some fender well modification and readjusting of the brake line location? Do I need spaces for the rear shocks to get and extra inch of lift?
For those of you with 35's any input would be greatly appreciated.
Paul
You don't need wheel spacers. They are a personal choice. You do not need brake line extenders unless you go with N74L shocks (or modify the stock mount). You should space up an inch in the rear and up to the 2.75" level up front. Details here: https://forum.ih8mud.com/showthread.php?t=150735
Wow. Those Toyo's must be fat suckas!
i believe the Toyo MTs overall width is 12.9" with a height of 34.9" (height from website, width from Hoser)
the BFG A/T KOs have an OW of 12.2" with a height of 34.6" (numbers from BFG site)
i also didnt have to touch my turnstops with though spacers
edit: those tire stats were for 315/75/16s
