Pick and pull
Oregon
Went to local pick and pull for some male and female pin connectors. While there i saw a steering wheel on a 97camry. They wanted 21$ for it and tbought what a great deal if it would fit to my 95LC. SO THE QUESTION REMAINS. Will a 97camry steering wheel fit on a 95LC? ANOTHER question is if i'm ever at the local pick and pull besides land cruisers, what vehicles are best to look for parts or wiring harnesses etc etc. thanks in advance!
The same vintage 4runners and minitrucks have a lot of good vacuum hoses and they share many of the same vacuum switching valves and in line vacuum delay fittings.
The Steering Wheel Hub is the same across the board.
Overall Wheel diameter and the shape/diameter of the rim varies a little vehicle to vehicle.
Also, if you are concerned about air bags, they may not be compatible. The timing of the bag is different for each vehicle and will likely be different from Camry to Land Cruiser. How different and in what way? No clue. If you want to remove the airbag, I believe it is possible to remove the unit from the backside of the horn pad before re-installing.
It will be a little different, but it will fit. For $21 go ahead and buy it and try it out!
You could stock up on York 210/209 compressors and do pretty well on the York OBA Kit thread. Lots of folks gonna need a compressor ;)
Thanks for tbe info. The air bag on tbe camry is seperated from the wheel. My wheel is coming apart more and more each day so a small variance in diamarwr
>Start hijack<
I have been to Pick & Pulls specifically to get a York Compressor. I found it is much easier to just buy one on the internet that is already rebuilt.
>End hijack<
@tlc1995 I think you will find that any steering wheel from that era is going to start coming apart, especially something from a pick & pull which doesn't get any use. Unfortunately, the only real options remaining to get a "like new" wheel are going to be expensive.
If I recall, the clock spring is the same on that vintage camry, so I would guess it is all the same
