Ok, so i'm replacing the PHH and can't seem to find hi-temp silicone tubing at any of the parts stores i go to. Anyone know where i can order some, or get some in the Atlanta area.
Thank for all the replys everbody, Cruiserdrew I would take you up on your offer, but I'm just going to go with the silicone kit because I want a solution that dosen't involve removing the upper metal portion of the hose. All the threads I've read on the green stripe, say that its not bendable enough to get on the pipe w/o removing it. I'm just gladthat it's not my HG leaking (knock on wood).
If you PM me your address, I will send you a length of Gates Green Stripe hose for free. It's perfect for this job, and in my opinion SUPERIOR to the silicone hose. I have a lot of it, and I'll cut you off the 4 inches you'll need (cut to the length you want) if you want me to. You can use standard hose clamps and it's easier to work with than the silicone hose. The down side is, you won't have it for a week, since I'm in Kalifornia.
. I used the 1FZFEPHH.com kit. Pretty simple with no other obstructions. BTW the old one looked pretty bad.Cruiserdrew,
Why do you think the Green Gates is better than silicone, thanks.
JMZ-
