PHH question
Snohomish WA
So my heater/defrost wasn't warming up until about of mile of driving. Checked the coolant and it was low. Though that was weird since I had the heater valve and PHH replaced at a local shop less than a year ago. Noticed a small leak while at the gas station yesterday.
Took a look at it today and it doesn't appear to be the throttle body hose or hose against the firewall. Seems to me like it's the PHH again. Just weird that's it's been less that 20k miles since it was replaced. And just for input, it's been in the 20's all week.
Anyone have any suggestions? I'm a UPS driver and I have next to no free time besides now-5pm today, then I'm pretty much 100% busy until Christmas day. Would I be OK just checking the fluids and topping it off until I have time?
With how little it's leaking, it seems like the clamps just aren't tight enough. But I don't want to get in there today Incase I accidentally break the knock sensor like alot of people have done. And yes I'm aware I should unclip it, just being over cautious because this is bad timing
Clean it up then tighten the clamps and keep eye on it prob loose clamps, or change it again
Could it be that it just needs tightening?
From what I can see, that's my guess. Looks like it's coming out the end just a little bit. I'll tighten them up a little, top off the coolant, and keep watching it
If you do change it, clean up any corrisoion on the metal pipes, if you don't might not seat as good, I've done them with silicon or normal rubber , I don't see the point in silicon but to each there own, I changed my original at 270 it looked fine when I cut it in half was Toyota rubber replaced with some Napa rubber had laying around seems to be holding up fine
I feel for you.. My birthday is on christmas and I hate this time of year, also a ups driver.... Anyways, I would try and tighten those clamps up a bit and see what that does...
Peak blows. This year has been extremely rough in particular
Looking at it again, that's a pretty bad leak (running all the way down block). Before tightening up those clamps, I would inspect hose for a tear/hole on the hose..
This is my first time in 16 years not working a peak (injury from work). UPS labor will do it to you. Be careful out there and don't be a RABBIT..ha:steer:
Coolant expands when cold. Very likely just the clamps aren't tight enough. I'd give them a snugging and top off with coolant.
Knock sensor is being stubborn. Do I push down on the clip or lift up? Can't see it since it's on the top side
Nevermind, didn't need to remove it just to get a wrench up there for a couple turns. They moved quite easily and got about 5 turns on them before they started to feel tight. So I'm gonna top it off and hope the problem was just loose clamps
Nice!
My guess is that they didn't come loose but were never tightened all the way. Ask me how I know. The leak wouldn't show up until it got cold enough.
Nice!
Kind of what I was thinking since coolant expands in colder temperatures. I had it replaced last winter, which was very mild and barely dipped into the 30's.
When pulling off the PHH how much coolant comes out?
Pretty much all of it. Which is why it is so catastrophic when it fails.
If you have fresh coolant and want to reuse it just get a garbage bag handy and pull the bottom radiator hose quickly ad stick iron to the bag. Then strain it through and old tshirt as you pour it back in when done.
Coolant is a PITA to get rid of.
