- Thread starter
- #21
That's easy enough! Let me just peruse the FSM.........The throttle body mounts to the front of the upper intake manifold.
If you are referring to the "water bypass #1 hose" it's not hard to do even without taking off the throttle body.Removing just the throttle body is pretty easy/straightforward and that will give you access to the phh neighbor (second hose). As far as your phh - either replace the hose and the pipe or do the phh workaround which eliminates the pipe and instead uses a length of hose to bypass the pipe. Either method is fine and reliable.
Now that you mention it, I think I bought that from Wits End. Ordered some Corbin clamps from BelMetric today for transmission cooler hoses, so should be covered there with the bypass hose.If you are referring to the "water bypass #1 hose" it's not hard to do even without taking off the throttle body.
You can reach everything from underneath. Line up the clamps on the hose and push it on. I've done a write-up on procedure someplace on here. It took me 15 minutes.
SO THAT"S what the white marks are for, good to know......On the bypass #1 hose:
Here's a hint....... Put the factory clamp on the new factory hose FIRST, then spit inside the hose for lubrication, then push it on until it bottoms against the block. You can do it blind.
The FACTORY hose has a white mark on it to align the ears if the factory clamp before you install it.
Makes it very simple and quick!
I apologize for the duplicate picturesSo this what I'm dealing with..., new radiator install, waiting on small parts to finish up. Everything that I've worked on so far is all anti-seize/Kroiled up so disassembly won't be hard if I have to pull the TB/upper manifold.View attachment 2697412View attachment 2697412
Yes, duly noted. I was aware of that. did not know about Loc-Tite though.Just as a reminder - anti-seize changes the torque values.
Since I am beyond paranoid about assembly and disassembly (having done it several times), I would recommend blue or purple thread locker instead. Still prevents corrosion. I especially use it when replacing factory bolts with stainless.
I'm still surviving rust..... "Hi, my name is Shane, I have a 24 year old Land Cruiser from the northeast..........." It was a decent deal at the time, $3600 with 251K on it. And that was right before prices took off!And, as a fellow rust survivor - good for you for saving one!
I do have a replacement heater valve waiting in the wings. As i research the PHH from the top end by removing the TB, that seems like a better approach.Make it easier on yourself and do the PHH extension over the brake booster. I wouldn't trust that rusty PHH tube.
Is it possible to replace the tube without pulling the manifold?Make it easier on yourself and do the PHH extension over the brake booster. I wouldn't trust that rusty PHH tube.
Possible but not easyIs it possible to replace the tube without pulling the manifold?
Just make sure you have your tetanus shots before you start!For me I found going in through the wheel well and removing the splash guard flaps gave the best access. Cutting off the clamps then slitting the hose to peel it off is how I did it. I loosened the bolt for the metal tube and removed the hose from the upper end so that it would pivot a little which was just enough to get the new hose in place. I just replaced it again for the hell of it since it was two years ago and I had the intake/head off for head gasket replacement anyway.
Just make sure you have your tetanus shots before you start!![]()
Dude, that's a great deal! So long as the rust isn't as bad as that PHH tube looks, you've got a great deal of a rig on your hands. I'd also get the workaround PHH tube. I bought it but never used it, since I had just enough patience to get the OEM method repaired and that patience barely made it!I'm still surviving rust..... "Hi, my name is Shane, I have a 24 year old Land Cruiser from the northeast..........." It was a decent deal at the time, $3600 with 251K on it. And that was right before prices took off!
