Performance tweaks
X2 on the timing advance, tweak it as far as you can... a little spark knock won't hurt it, but excessive knock will kill it.
In my 94 I advanced it from the factory 3 degrees to about 7 or 8 with just a very slight knock at part throttle occasionally.
2nd tip is to disable the EGR...pull a vacuum hose off it. This will give you a slight improvement in throttle response and the engine will run a tad smoother. Hook it back up for emissions testing.
The EGR system is strictly there to lower NOX by dumping exhaust gas back into the intake to lower combustion temps.
Your engine will run better without it.
these 2 things together will give you a noticeable improvement and they're free!
Do you need to cap th ehose off? or just disconnect it?
thanks
For the 3Fe there aren't many options.
Do a custom exhaust with hi flow cats and muffler/s
Clean and bore the throttle body
have the injectors balanced
Synthetics in everything
De-smog
Gears
Advance the timing
There are some that have turbo'd them
Gotta love the 3fe power. I was fully loaded driving up the 5 out of Bakersfield @ 45-50mph full throttle.
I'll look into disconnecting my EGR and some of those other tips. Thanks for all your help.
If you want a huge bump for free....... adjust your transmission throttle cable so it has only slight slack with the throttle plate closed, then adjust from there to your liking. The truck will will feel a ton better when it actually revs into the powerband before upshifting.
Desmog is absolutely worth the trouble. It's like an entirely different motor now.:)
