Peculiar Diff Lock Problem
Cincinnati, OH
I looked in the faq's and i did a search, but can't find my specific problem.
The problem i am having is when i go to lock my front and rear lockers. When i turn the knob the rear flashes and then locks but the front light never comes on. I have tested these before and they have worked fine (about 3 months ago)
Here is what i do.
1. Go in park
2. Go in 4Lo
3. Notice my Center Diff is Locked
4. Turn the Knob all the way to the right
5. Notice my rear diff is flashing but my front diff light doesn't come on at all
I thought maybe the light wasn't working, but when i start my car both lights come on.
Any ideas what the prob is?
So the light doesn't even blink?
Have someone stand near the front tire and listen for the motor to engage/disengage as you turn the switch. Truck in lo, engine off, key in ACC.
Hmm, could also be that the indicator sensor has a problem and isn't coming online with the turn of the switch?
Listen to see if the DC actuator motor is working before do anything else. If thats not running, you won't be locked.
ok, i will use those steps to see if the DC actuator motor is working in the morning, and update you guys when i figure that out
Do both locker lights flash when you first turn the key on?
-Spike
-Spike
Yes, when i put the key in ACC i think it is, both lights come on.
well then, i went to see if i could hear the actuator, i hear it actuate. I look at my dash, it actuated and locked.
So then i got on the road, locked them, and they all locked up. I wonder what had happend.
