PCV: Technical and ethical questions
RDU, NC
I understand the PCV system, but what I don't get is why is it a good idea to pump that hot air from the upper end into the throttle body + intake charge?
It seems that keeping a cooler intake charge is a major objective of many folks and companies.
So the technical question is: Why? and what would happen if the PCV were not vented to the TB, but to the atmosphere? (Out of curiousity, how much affect does the airflow from the PCV have on intake charge temp?)
The ethical question is: what is the impact of, say, using a catch can for the oil, plugging the port on the TB, and installing some type of filter on the PCV hose vented to the atmosphere?
Howdy! Basically no cars had PCV systems before 1967. If you are lucky enough to see some old iron running down the road, you can see a trace/trail of steam and smoke coming from a tube that runs from the valve cover down past the oil pan. Besides the pollution value, it has energy value as it is mostly fuel and oil mist. If this mist is cooled, it will condense into larger particles that are harder to burn efficiently when re-introduced to the fuel stream. I think it is mandated by Federal Law, but it is left up to individual states to enforce. John
I had to go back and look this up because I was shocked when I first read it. According to How to Tune and Modify Engine Mangement System (2nd ed, page 170) the combination of introducing a PCV system and eliminating vented oil filler caps in the last 60s reduced total emissions by 1/3. Now there isn't any evidence presented in this book to support this so take that for what it's worth (this book is generally excellent so I have no reason to doubt it). Another tidbit of data on this point is that when registering a pre-smog vehicle in many cases all they care about is that the engine in the vehicle has a functioning PCV system.
