Patch panel prices
Sacramento, CA
I am doing some body work and am at a point where I need to call in an expert. There are a few spots on the back of my cruiser that need some love.. aka patch work.
I seriously have no idea how much it would cost to have these spots cut out and replaced. I am going to do all my own painting but need a body guy to weld some new metal in place first, sand down the weld spots, and I will take care of the rest.
I realize this is a random question, and every city is different, but roughly how much should I expect to pay to fix these rusted spots? I am in Sacramento.
NOTE: The PO replaced the rear sill so the metal is good there. The rusted spot next to is not so good :frown:
depends where you go body shop will charge an hourly rate the kid down the road not so much .
That really should had the whole rear sill replaced. Adding a piece under the doors and the patching the corners separate is not how you want to repair a sill. The sill is one continuous piece. The U channel wraps around front corner under the doors and then the other corner. Wheel wells and hard top have a lot of leverage against the sill.
I just started reading up about rear sills and saw the same thing. The PO did some really funk stuff with the body that I am uncovering now. Sort of sucks. I am hoping to do a frame off and fix a lof of these issues in the coming years. Unfortunately for now I have to fix it the best I can.
Stress isn't as bad If not running a hard top. Have two old project 40s that the barn doors are too far apart at the top from the weight of a hard top and rusted sill.
I was just checking out Real Steel for a sill and two patch panels. The damage isnt too bad and I know they make quality products. The problem is finding someone locally that I trust to do the work. Body work isnt my forte.
Seems like you are afraid of doing the job yourself. ? If you are looking for cheap people for good work, especially in Cali, good luck. Many people here take the plunge and get into personal repair, there is a lot of support here.
Based off the pics above. If you're already planning to do a frame off in a few years then I'd treat the rust chemically plus some POR15 or the like, skim coat it, then touch up the paint.
Living where you do, a few years of use shouldn't allow that rust to grow in a way that would significantly change how you'd address/correct it when doing a frame off.
I agree with S4Cruiser.
You have done some remarkable touchups on your 40 and those areas you pointed out would be no problem for you to fix, while waiting for your frame off. But as the saying goes "where there's smoke there's fire" applies to the rear sill. When it does come time, replace the whole unit.
@1969FJ I agree, body shop work isn't cheap and no way am I going to pay for low quality work. I have never had any body work done before so I am not sure what to expect when I roll up to a body shop for a quote? $500? $1500?.
I think I am going to tackle the rear sill myself once I build up my welding skills. They are sadly non-existent but I am planning on learning how. I think I am going to take the rear sill on next year some time. For now, @S4Cruiser and @kevos37 's plan is probably the most practical. I will post pictures of my progress.
Cut out the SPECIFIC metal and skip the entire patch panel approach. just cut square panels bend to fit, trim and weld them in.
The reason is your other metal looks pretty good and its harder to do larger patches especially if your not too familiar with the job.
Pros can charge 50 to 150 bucks an hour... Sometimes you can get a "job" quote which may be cheaper. I've found that local shops that do work for local car dealers can be a great option for smaller jobs with fair pricing.
