Part time kit ?
victoria
I have to replace my transfer case barring to the tail shaft and I was thinking why it is out do I put a part time kit in it in australia evey one put the marks 4x4 part time kit is has any one else done this ?
Is it worth it
Several here have done it. Personally, I don't see the benefit, other than some less everyday wear on parts.
Assume you drive 10000 miles/year and currently get 10 mpg. Then, by spending $1000 and installing the kit, you get 5% better mpg. So, you save about $75/year if gas stays where it's at now. Again, rough estimates, but it should take you about 13 years to break even.
I drive both, and prefer the part time truck. You loose the ABS, which may be a game changer. Other than that, you turn easilier, and accelerate better. It make the truck feel about 500lbs lighter. The bonus is the front axle wear and tear issues, as well if you break a bird on trail, getting home is not an issue. I get the same to better range with my part time on 35"s as I do with my full time on 32"s after speedo correction. I welded my centre diff, so that saved me a couple of bucks, and had some mini-truck hubs laying around. Best single mod I've done
Ability to shut down front drive line in case of birf failure, reduced wear on whole front driveline, less importance on having a front CV shaft depending on lift.. Most people report no noticeable difference in mileage.
Only real drawbacks I see are cost and AWD with a center diff arguably does do better than 4wd in ice/snow.. Probably not much of an issue in Australia
You don't have to have a part time kit to drive home if you break a something in the front end. Just a CDL switch. Pull the front DS, lock the CDL...instant part time kit.
Better have installed locking hubs already if you want the front end to be truly disconnected.
agreed
I did it because I want a lokka in the front and rear and don't have to worry about expensive lockers. A part time and two lokkas and I was done! Triple locked
Drive YOUR rig without a front driveline prior to going part time. Don't go PT for MPG reasons.
This right here.
I've driven without a front drive shaft as well as without a rear one. Personally, I dislike either one for handling reasons. The truck has very predictable handling characteristics as designed. Not so much without one or the other drive line attached.
