My setup is 3x locked, CDL button, pin 7 mod, Aisin part time hubs on the front.
Normal operation = full time AWD (CDL unlocked, F&R unlocked, part time hubs engaged)
With this hardware, the following is also possible:
4x4 = CDL locked, F&R unlocked, part time hubs engaged
4x4 w/ rear diff locked = CDL & rear diff locked, front diffs unlocked, part time hubs engaged
4x4 w/ front & rear diff locked = CDL, front, & rear diffs locked, part time hubs engaged
2wd = CDL locked, F&R unlocked, part time hubs disengaged
2wd positrac = CDL, & rear diff locked, front diff unlocked, part time hubs disengaged
I don't have a true part time kit, in that I don't have a spool in the center diff, so I have no means of disengaging the front driveline from the transfer case, just the front wheels from the driveline. Making the TC a true part-time setup would mean losing AWD, and I'd rather keep AWD for the winter driving I do. I needed to replace the front drive plates, and opted for part time hubs instead. I didn't expect any driveline wear or mpg advantages, but it does allow for rear diff locked 2wd winter hooning, lol. It will also come in handy when it comes time to strap it to the dyno for a tune, as there's no AWD dyno's for about 8 hours in any direction. And they look cooler. It drives a lot different in 2wd vs. AWD, the front is a lot lighter, it feels a lot less planted, I think I prefer it driving around town in the summer in 2wd.
My question is this: with the front diff unlocked, is there any reason to have both front hubs disengaged rather than just the driver side (or the other)? In 2wd, the CDL is locked, sending 50% of the power to the rear axle no matter what, with one hub on the front disengaged all the power to the front should be dumped off on the side that isn't connected to anything, and none should go to the side that's still engaged, correct? Is there any danger to the front diff from having to direct all the power to one side all the time, or any other reasons this is a stupid idea? Would it drive funny with one wheel connected to the driveline, but receiving no power, the other disconnected from the driveline?
