Part numbers and advice needed
Tucson
Hey everyone,
I posted a couple pictures where you can see I replaced a couple firewall hoses with blue silicon hoses. The system was flushed and Toyota red coolant was used. Now I'm noticing the hose(s) to the right (toward the US driver's side) of the upper blue hose is leaking red. My truck is a 93 with 146k. Anyone know the part numbers for these hoses?
Also, I noticed there is a wiring harness around that area that runs into the dash. The protective wrap is pretty much nonexistent and the harness wires are exposed and touching a hose. My 80 has spent it's life in the heat of Texas and Arizona (Bear Down!). Suggestions for rewrapping that harness? I'm sure I can get away with electrical tape but was hoping for a better solution.
Thanks for the input :flipoff2:
Lemme just get this back to the top...better chance of getting someone to chime in :)
Thanks for pointing me in the right direction. Guess I'll replace the heather valve and the hoses just to be on the safe side. How about wrapping that bare wiring harness? Suggestions?
Nice guys! Thanks for the input.
I have heard guys use heat tape on the harness you mention. There are threads about it. It is a common area for shorts and bad engine electrical gremlins, so I recommend you take care of it soon. IIRC, that is basically your engine harness with all its sensors which makes its way to/through the firewall to the ECU, so it is a critical area.
