Part Number??
I have been through my EPC over and over. Does anyone know the part number for this brackets? They allow the front locker wiring harness to mount to the sway bar.
82710-60011 -clamp
82710-60020 - clamp
90119-06416 - screws, order 2
I had the hardest time tracking these numbers down when I did my elocker retrofit. And yes 2 different part numbers because 1 is longer than the other.
82710-60011 x2
82710-60020 is replaced by 82710-60011
90119-06416 is replaced by 90080-11166
So I guess I am wrong about one being longer than the other? It has been a while since I did the retrofit.
You are not wrong.
The originals were two different lengths. MR T consolidated the part number and changed the bolt part number on you.
Thanks guys! Yeah, this is the last piece of my locker retro, hopefully.
JP did you bother with the grey wire tie in the engine bay near the plug? If so do you have the part number for that as well?
A zip-tie is a zip-tie unless you are doing a 100 point Concours restoration....:lol:
I dont have a picture of it but the zip tie plastic clamp thingy he is refering to is (was) part # 90463-10338
There is a spot on the front locker harness for it and it secures the harnes to the body near the air cleaner.
Just picked up a 90463-10338 to secure the harness near the air cleaner and it doesn't seem to be right. Any one else know what P/N secures the harness in the fender hole near the air cleaner?
