For Sale Park City, UT 1988 FJ62 Land Cruiser
Park City, UT
Year
1988
  1. 60 Series
Park City, Utah 84098 United States
Mileage
70000
Color
White
1988 FJ62 Land Cruiser with 5.3 Vortec Engine Swap $40k
Get ready to have some fun in this cruiser - ready for anywhere you want to go.
We have had a blast in this cruiser and want him to go to a good family.
-This vehicle is in excellent condition. Professionally converted drivetrain.
-5.3 Vortec purchased from Tilden Motorsports as was the 4L60e transmission
The engine had about 65k when we purchased it from the owner that did the rebuild and approximately 236k on the chasis. We have put under 4k on it. Garage kept and washed before we put him away.
-Ice cold A/C
-4 row copper radiator, US radiator
-Greasable bolts, anti-inversion shackles
-Old Man emu suspension
-Pacific fabrication wiring harness
-Upgraded headlight harness
-Custom long range fuel tank with protection plate -35 gallons
-Super Tough Diamond Axles, 4.10 gearing
-Upgraded brakes, Discs all around and upgraded master cylinder
-Trail tailor tailgate storage
-Storage on rear cargo side panels also
-Cerullo seats/matching rear upholstery
-4 plus front bumper
-Custom dash with autometer gauges
-Custom aluminum door panels
-Lokar shifter with shift indicator
-Clean intact headliner
-No car this age is completely rust free, however, this car comes close. It does have a few age appropriate paint blemishes but over all is VERY solid.
-Protection plate on the long range fuel tank was stripped and painted
-ARB front and read Air Lockers with onboard air with plastic coated stainless steel braided tubing
-super tough Diamond axles withnew 5.29 gears installed by Cruiser Outfitters
-Old leaf spring perches were removed and new ones welded on going from spring under to spring over
-rebuilt both front and rear axles with all new bearings, seals, grease
-all new bushings and hardware in leaf springs
-Ford shock towers for longer travel shocks
-Bilstein 5125 series shocks – 33-185576
-Bump stops to make sure no damage could be done at full articulation
-Marlin Crawler High Steer kit which included the upgraded 80 series pitman arm
-80 series power steering box- West Texas Offroad rebuild it. tapped and ported ready for hydro-assist.
-HD Drag Link and tie rod from YotaMaster
-master cylinder replaced with a Wilwood MC with extra large body
-Wilwood proportioning valve installed
-upgraded brakes- Front brakes are off a 2007 4Runner V8
-brake lines were replaced with hard lines. Note: the rear still has some stainless steel braided lines, they seems to work well back there.
-upgraded big brake kit in front with new ProStop calipers and a 13.3 inch drilled and slotted rotor.
-Pro Comp 37x12.50R17LT tires and wheels.
-4 Plus front bumper with winch, 2 Rock Country4 Inch LED lights and one 12 Inch.
-4 Plus Rear bumper and ladder withsingle jerry can holder, Hi Jack lift brackets and rear lights.
-new fuse box under the hood for lights
-Bluetooth stereo with cameras
-Gamaviti roof rack
-Antenna for cb radio on rear bumper
It’s my first go on Ih8mud… it’s a really sweet vehicle! I’ll figure out how to set up a link for more photos. It will not disappoint whoever buys it that’s for sure!!!
Make sure you check your PMs. It’s the envelope at the top of the forum. That is how most people will get in touch.
This looks like my old rig did you buy it from someone on this forum?
