This is the diagram that fits my 78 BJ40.
The trick is in the brake pedal switch. It's a double switch.
The parking section works through the pressure sensors under the MC.
The low oil section works through the brake pedal switch.
So check the wiring at the pressure switches. They are normally closed and open up when you hit the pedal and build pressure.
If the oil is low or you have a leak, the switches stay close and the light wil come up.
Good luck,
Rudi
Is it just me or is this diagram wrong. The wire out of the parking brake switch should go to ground not be tied into the brake pedal switch. The way it is now the parking park light will only have a path to ground when one of the two brake waring switches on the bottom of the brake master is made. The waring light circuit is fine but the ground for the parking brake light should be indepenent of the waring light ground which is thru the master cylinder low fluid switches.
Gentlemen, I have a 78 40 that I can't get the parking light to come on.I have power to the switch and through dash light. I think it's a ground problem, not sure.
Now step on the pedal, light goes out. Because the pressure switches open up and disconnect to ground. This is also a check function to see if your brake system works okay. If you step on the pedal and the light stays on it means trouble under the hood.
See the 2 red wires under the MC. The red wires are my colors not the OEM colors (thanks to the PO).
Thank you all for the help, does anybody know how you test the brake sensors with a testor?
JDAs I said before, this is the diagram of my '78 BJ40.
Yes it is a funny set up but it works. I asked myself the question, why did Toyota merge 2 systems into 1 brake light?
Why not 2 seperate circuits with a light bulb each?
It took me an hour to figure out the double function of the pedal switch. Let me try to explain.
Situation: engine off, key on.
Pull the parking brake, light comes on. Light has ground via the 2 pressure switches which are normally closed.
Start engine, light is on. Release the parking brake, light goes out. Step on the pedal. Light stays out. So far so good.
Now you have a oil leak or no oil situation. Here is the trick:
When you step on the pedal the rear brake lights goes on via the A-A' section of the switch. But you have a leak so the pedal goes deeper. Now the B-B' section takes over the parking brake switch to keep the circuit going. So the power route is now: fuse - light - B-B' section - pressure switch(es) and because of the leak or no oil the pressure switch stays closed so the light comes on.
This is how it works in my BJ. I know that there are different configurations with oil sensors in the lids, 2 light bulbs and more funny set-ups. I think that this is the most common configuartion for the late 70's series.
Rudi
Duffintap,how did you solve the ground issue,and what was it? I think that could be my problem,Thanks
