Paint on Knuckle ball or....
Eagle, ID
Hi, I was told by the PO that the front axle had been "serviced", but I have no idea to what extent. I noticed quite a bit of seepage, mixed with grime, brake dust and whatever else at the bottom of the knuckle ball. Nasty job to clean it up. So all cleaned and checked the Moly level with a zip tie and it could use refilled, but it was probably 25% full and the moly was good, not soupy. I will buy a tube of Moly and a gun tomorrow, but see in the pic that definitive line? I know there should be a grease line, but that line is something else. What is that? burnt up oil? Paint? I have a chronic rear main seal leak, but not terrible. I tried WD40 and scrubbed with paper towels and it lightened up somewhat, but that stuff is on there. What's the best way to clean these up without screwing anything up? Also, is there a way to tell visually if I had a full birf job done? The service records are spotty. I just baselined all fluids including cooling system this week and now want to turn to my front axle.
Thanks, Shane
Factory paint. Also, you don't want to clean the grease off that spherical surface, as that felt seal has a rubber lip inside it that should be lubed and sliding on a film of grease that constantly oozes out of the birf chamber to keep it lubed. It's called a weep seal and is supposed to constantly do this. Cleaning it to dry metal shouldn't be done. The picture makes the black painted metal seal ring we can see look fairly new, but that's guessing. Fill the birf and drive it. A few squirts per oil change from then on.
DougM
I've seen a few like this. It is most likely paint. Nothing to really worry about though
Paint...the knuckle only turns so far left or right.
Ideally you keep the cavity full +/- with moly grease, this helps lube the sliding surfaces while keeping water from entering because you have a layer of grease coating the knuckle.
I like to put the grease gun head into the fill hole, as you pump, grease slowly pushes out the grease gun head out.
Turn you wheels to either side while doing this as it gives you lots of room to work.
These things will take one and a half tubes of grease. when empty...
... Ideally you keep the cavity full +/- with moly grease, this helps lube the sliding surfaces while keeping water from entering because you have a layer of grease coating the knuckle.
They need to be ~1/2-3/4 full, if too full grease pushes out past all of the seals.
If the part of the birf that is exposed wasn't painted it would rust. I imagine the rust would wreak havoc upon the seals. The part where the paint is gone/worn away is fine because it gets the coating of moly as you turn. I agree with Doug about the new seal ring - that would seem to indicate they had been redone.
Mine has factory paint, no issues, since they are not chrome plated, there should be some grease there.:popcorn:
