jmarsh1977 said:
My thought was to retain a length of the existing harness (where original) so I could refer to my original '71 wiring diagram. So the original connector from the component (let's say a side marker light) would retain it's original mate to the existing connector on the stock wiring harness...and later down the line (6 inches?) I would snip the stock wire and have the painless wire soldered w/ heatshrink over it. Does that seem retarded or OK? That way if I have to replace a light or starter or whatever I could plug in easily to the original connectors. Otherwise wouldn't I have to keep cutting and splicing in replacements? I was worried about how much spare wire length I would need for a scenario like this. I thought about about doubling some lengths over and zip tying the bundles together to provide extra length for future rerouting or changing out faulty connections.
That's what I did for the single connectors, but only kept the male end, stuck that into a new female on the Painless side; for the multi-connectors, I converted them into a bunch of single connectors (have to trace each wire correctly). But having connectors is helpful, I think.
In my case, parts of the old wiring harness were completely fine and would have probably lasted another 30 years, but would I have had peace of mind? The OEM fuseblock had broken and faulty connections in my case with some hack wiring; that motivated me to exchange for a new block. Wish they had the small waterproofs when I started, space-wise would have been easier. Finding the tiny fuses is MUCH more difficult.
Replacement for the 50amp fuse is also difficult to find, there are two types on market, you want the one with slots on the side.
How long it takes depends on your preparation (identifying and tracing existing wires and sorting the new wires) and the wiring diagrams you consult. It took us (2 people) about a month working every other evening and at least one full day on the weekends.
Some things I learned:
- the diagram in the Haynes manual was closest to OEM (at least for pre-73), the FSM had a diagram onloy for later models (there are some diagrams in the etch section)
- the aftermarket wiring kits are based on GM's way of thinking, Toyota had a different philosophy: major differences are the ground circuit and few actualy ground connections in the stock harness and the lack of proper consideration of Toyota switch functions in the aftermarket wiring kit; you will find that Toyota's approach to coloring the wires for the different functions was quite rational
- do not cut wires between hazard switch, brake switches and turn signal switch; at least before you do, figure out where each goes because you will have to reconstruct these connections, they do not come with the wiring kit; otherwise, your switches will not work
- even though the wires themselves are labeled, you will not be able to see much once you have them under the dash, better to label each with flags you can actually read, take a light colored tape
- you are better off to keep each wire until you have the new one in place, then pull the old one; even my husband was finally convinced that this was the way to go (rather than cutting everything out in the beginning, we would have had some major problems)
- get those flex tube looms and use them liberally as soon as you have a group of wires traced, you won't believe the rats nest you will create behind the gauge panel if you wait until the end (I had to disconnect and restring a number of wires to clean it up)
- some small things you will have to make yourself, such as the connections to the side marker/blinker lights
- best to ground every device, can never have too much ground, the instrument cluster will need its own ground
- working with relays for the bigger consumers is highly recommended (horn, headlights, accessory lights, amplifier/equalizer, electric fan, ARB compressor etc.)
- have spare fuses and relays handy for the time when you test; relays for blinker and hazard lights should be same frequency (same manufacturer)
- if the number of circuits in your replacement fuse block is not enough, you can mount an accessory fuse block
- most of the ordinary parts store rubber grommets do not fit the stock holes
- yes, do disconnect the battery
I may not remember everything, PM me if you have questions.
I found the heat shrinkable connectors the best (spendy); waterproof connectors can be had at auto parts stores and Ace (no one store has all you want), they are also vibration resistant. I wrote all the tracing down and every step as we re-strung as well.
Feel free to e-mail with questions.
Good luck, Claudia
PS: it is NOT painless or EZ!
