Driving my girlfriend to work, dashboard lights up. Ugh... check gauges. all fine. engine running smoothly. I chance the extra block to her work before checking it out in the parking lot. slowing down to a stop, there was a THUNK! not a drive-shaft-needs-lube thunk. I have that too. its different. Car off. hood open. all fluids that i can check are fine. no noticeable leaks. i start up the engine again after deciding it probably had something to do with my brakes. those have sensors, right? so I decide to drive home to my computer using the hand brake (~3 miles). During the drive, it THUNKED around 5-7 mph on slow down every time. pedal brake or hand brake. now I'm thinking its first gear. sure enough, manually shifting to 1st THUNKED hard. so i push the 2nd button. thunk is gone the rest of the drive. first gear is mad at me. get home to a computer and verify p0778. shift solenoid b. do i have an electrical problem? a transmission problem? or a low fluid (with no dipstick to check) problem? search had ZERO results for this code.
2004 LC @120,000
2004 LC @120,000
