P0401 Poll
Eagle, ID
what all did you have to replace to fix this code?
the regulator?
The Valve?
The VSV?
or what combination of the the three?
so far i have cleaned the sensor, replaced EGR new from Cdan, and new blue top vacume modulator.... till throwing codes......
btw, i searched, there is a ton of info, but its pretty all over the place. one thread with who had to replace what is all i want.
I replaced the EGR Modulator. Code reset and hasn't come back in 7k miles.
My fix cost less than $6 and took an hour:
I disassembled the EGR system and removed all vacuum lines. I ran Seafoam through the vacuum lines; and I cleaned up the EGR filter and pot with Seafoam. Then I reconnected all vac lines and dribbled some Seafoam into them. Lastly, I pulled the PCV vent hose from the valve cover - other end connects to the throttle body, in front of the throttle plate - and poured Seafoam into it while the truck was running. I turned it off after about 15 seconds, let it sit for a while, started it back up, and sucked more Seafoam in through a vacuum line, turned it off and let it sit.
At next startup, after it got done smoking, the dang thing ran smoother than it has since I got it and my P401 is gone! I am very surprised at how smooth it is, and am anxious to see if my mpg has been affected.
When reinstalling the vacuum lines to the EGR, I pulled the two from the throttle body then was having a hell of a time reinstalling them through the throttle/cruise mechanism. Said enough, hacked them down to about 8 inches, sheathed them, and just ran them direct over the throttle. Why Mr. T ran them down the TB is a mystery.............
Code 71 on a '94 but I've tested the EGR Valve which passed. Cleaned the EGR Temp Sensor. Cleaned out vacuum lines between EGR Modulator and EGR Valve and Throttle Body. fyi, the vacuum line running out the bottom of the EGR Modulator on mine was very congested, but cleaning it out didnt seem to help.
Still no joy, I'm CEL all the time. Maybe I'll run the seafoam.
Replaced VSV. It failed the FSM resistance test and registered wide open circuit.
Also of course cleaned the fawk out of the throttle body and replaced the egr system vacuum hoses.
See the above post re: 1994.
VSV
Replaced the EGR modulator. No fix.
Replaced the EGR valve. No fix.
Replaced the VSV for EGR. Fix. 4+ years and 75k miles. Probably ready to fail again.
-B-
Took the EGR off cleaned it up and put back together, being about 6 months P0401 free:cheers:
Presented for your viewing pleasure, my canned answer:
EGR repair on the late OBDII 80 is CONSISTANTY INCONSISTANT.
No two vehicles will fix in the same manner. It is best to follow the trouble-shooting logic in the service manual (you do have one, don't you? If not, you need one anyway). The main components are the VSV, modulator, EGR valve and tempreature sensor. In addition I have seen plugged vacuum passages. Some vehicles will require one of the above, some will need a combination and a rare few will need the whole 9 yards.
Bottom line, you can throw parts at it til you fix it or you can diagnose it first and then proceed. The latter may still not be completely sucessful but you will at least delay the flushing sound heard each time you reach for your billfold.
D-
