P0401 Last Resort
Ventura, CA
Yes, I’ve read endless threads on this issue as I’ve dealt with it in and off since I’ve owned my truck. From what I can tell I’ve done all the “normal” fixes.
1997 40th anniversary edition, 360,xxx miles.
Attempted fixes:
-replace egr
-replace modulator
-replace vsv
A few months ago I did a full top end rebuild, replacing all vacuum lines in the process.
I’m in CA and need to get it smogged, any time I reset the code, I’ve got to get the readiness sensors good to go - when I perform the readiness protocols, eventually it throws the code.
I’d rather not seal off the system as some have suggested.
Any other things I can try? Seems to be an absurd issue with the car’s emissions system. My actual smog numbers are great.
Appreciate it.
By the way, the test plug below looks very factory and achieves egr readiness
No it doesn't:
"Bear in mind, you have to have ECM readiness before you do this and if you disconnect your battery you will loose readiness and not get it back unless you do some other work."
Attempted fixes:
-replace egr
-replace modulator
-replace vsv
Appreciate it.
Is the egr port getting hot? Might be a bad sensor if it is. If it's not, then is there vacuum on the egr valve itself? If so then bad egr. If not then bad modulator or vsv or plugged port.
Yes, readiness is tricky, although readiness is not absolutely necessary depending on your emissions jurisdiction. I am unfamiliar with how CA deals with readiness though. You can get readiness with my plug installed, it just means you have to tear into the wiring in the passenger kick panel and mess with some relays.
You can just bypass the vsv
CA requires readiness for OBD2. 1995 = OBD1, which is why 1995 is the best year land cruiser ever
Test plug
1996-1999 you are allowed any ONE incomplete monitor and you will still pass.
Attempted fixes:
-replace egr
-replace modulator
-replace vsv
Appreciate it.
You haven't said, but have you tested the EGR system according to the FSM?
Speaking of last resorts...I have the test plug and still getting a light shortly after clearing the code, every time. I've tested the plug and it's testing good for resistance. Where in the wiring harness should I look for failure? Thanks to IH8Mud, I've inspected as much of the harness that I can readily access and I'm at wit's end trying to clear this damn light. Is there anything else in the vehicle (bad O2 sensor, stuck VSV, etc) that would cause a P0141 to trip, even with the test plug?
... that would cause a P0141 to trip, even with the test plug?
That is a O2 sensor code has nothing to do with the EGR.
