- Thread starter
- #41
I wasn't trying to be rude with my comment BTW.
Huh? What did I miss?
Does the brand new OEM shortblock (for $2787.06) include the rotating assembly also or just the engine block? If it does, why would you bore out the new block to a 4.7?
OK decision time.
* Going to stay with the 4.5 but the decision to stay with mine and rebuild or buy a new short block will be determined most likely tomorrow.
* Having the S/C checked at Magnusen in Ventura thanks to a good tip.
* The LX is going to get worked on at K&H starting later this week.
* The block, regardless of which I use, will be bored out to 4.7 (2mm over).
* I need to order the Cometic gasket and the ARP headbolts this week.
* I will work with Onur to determine what else I will need.
* The S/C is finally going to get installed.
If you are going to bore it over built yours or buy a core motor. Don't buy a new shortblock to do that. Not worth it. Lantank made the unobtainium bushing and you can buy it from AJKoverland (I think). If you use a new shortblock you will buy a lot of parts double.
Budget about $7k for a drive in, drive out regular rebuild. We have priced it either way. New shortblock vs rebuilding existing. Both work out about the same depending on your machining costs. One you pay Beno for parts, one you pay your happy machine shop. If you do not have access to a reliable machine shop that you can trust, then trust Toyota.
4.7 Swap is about $15k and that is with a used drivetrain. If you want a rebuilt motor, then it will be $6k on top of that.
Of all the options, I would take a Turbo 1FZ above anything else.
dropping a 93/94 motor in a newer truck is going to require tearing the engine down as well as swapping other things over.
I'd be inclined to use the present engine and just rework it.
Damn forgot about the differences there.Yeah, and I was just noticing how much the Sub-Zero 2.0-mm overbore pistons and goodies cost!!!!
Or buy a cheap Toyota econobox
hahahahaha, not with my wife. She wants her new vehicle and a cheap econobox will not make for a warm bed to crawl into.
New short block runs about $2787.06 with the smart shopper price.
sleeoffroad: could you list the parts, rough costs, details (or link) on what is required for a turbo 1FZFE build, advantages, disadvantages compared to a SC or normally aspirated truck?? IDK
