Overhead LCD install problems
Pleasant Grove, Utah
Overhead LCD install problems NOW WITH PICTURES
:clap:NOW UPDATED WITH PICTURES.... WAY DOWN THE PAGE>>
I just installed an LCD screen in place of the Dome light in my LX.. I was trying to get the dome lights on the lcd to work with the front doors, just like the stock light did.. long story short, I tried every different combination I could think of without any luck. In the end I blew the 10 amp fuse.. So I gave up with the LCD dome light, I just wired the + and - from the dome light plug and the LCD works great, I have to turn on the Dome by hand, no auto on with the doors.. SO here is my problem when I was finished I noticed that the DOOR open light was on, on the dash and the lower door light stay on.. I checked all the door switches and they are fine!!!! Did I mess up the ground by removing the stock dome light? or did I cook something when I blew the fuse?? any help would be great...
I removed the fuse so that my battery wouldnt die while I try and find out what is wrong...
thanks Bret
Umm, do you mean "LED" lights? Never heard of an LCD screen in place of the dome light.
LCD "Liquid crystal display" It is a 10.4 inch LCD screen for my DVD player...
Someone must know something??
I even checked the wires from the door switches up to the plugs by the firewall, they are all good..
I know has everything to do with messing with the Dome light or blowing the fuse, but I don't know what other component I may have toasted or if the ground at the dome light need to be connected to something???
HELP!
thanks
Bret
The stock toyota lights are a ground switched system . (IE the door switch grounds the ckt to make the lights come on )
You may have the wire that comes up to the light grounded or pinched making the lights stay on and door open light .
I think I know what is wrong.
There should be a two wire connector coming into the dome light that you are using for the LCD monitor. The two wires are +12V and door triggered ground. The dome light wiring DOES NOT HAVE GROUND as one of the screw on the dome light provides the grounding.
That helps also ! and it would explain why they have hooked the ground to the cross member with 2 of the dome light screws.. I will need to uninstall it and see what I can find..
thanks for the help
Bret
UPDATE!
I went out and unhooked the power and ground wires and guess what the door a-jar light went off, I checked both wires in the plug and the really funny thing is that they are both positive even when the door is open.. (don't really care) I plugged the power into one side of the plug and the little red man came on.. so a changed it to the other side of the plug and he went away.... so now the LCD works great, with manual dome light activation.. That is good enough for me!!!!!!!!!!!!!!!!!!!
thanks a ton..
PS. i tried the door switch trigger wire from the LCD (-) to the other side of the plug and nothing!! so I tried the other door switch trigger wire from the LCD (+) and the lights just stayed on..
go figure...
I am just happy that the little red man is gone from the dash!!!
I will need to do a write up on my new system, it rocks!
I installed a:
1. eclipse AVN6600 in dash LCD NAV unit
2. an eclipse 5962 (six disc changer) in the stock changer location
3. Eclipse color backup camera (sweet)
4. 60 gig Ipod mounted in the center console with full control on the 6600
5. JL Audio 8W3v2, 8 inch Subwoofer in the side of the center console ( a ton of work to seal and brace the center console ) in place of the stock 4" sub and monster cd changer.
6. 200 watt mono amp under the driver seat to run the Sub
7. I put Audio/Video jacks and power to the back of the center console so that my kids can plug their Ipod video in and watch it on the 6600 and also the Overhead LCD and it charges the Ipod as you listen
8. A 10.4 inch over head LCD with IR transmission for wireless head phones that is run by one of the 2 DVD drives in the 6600.
9. replaced the stock door speakers with 6.5 inch eclipse 3 way's front and back
10. installed remote tweeters in each door that face the people that want to hear the music, not there knees..
and that is about it.. I have spent about a week installing all of it and the LCD was the last component!!!
thanks again
Bret
I think what was confusing people was that you were trying to get the LCD to work with your doors like a light? Does your LCD screen have a light in it? Why would you want a monitor to work off of the door switches?
Can't wait to see all your hard work and glad you figured out the problem.
Got pictures???
please, post some pix so we can all admire your write-up. thanks
Hope you installed your LCD as far to the front as possible, I had to reinstall mine twice until I get it right because my kids at the corners seats of the 2nd row couldn't watch the screen well and it only worked fine for the middle seat and all at the third row.
That posed a problem as to hold firmly the screen to the OEM brace since it was upfront and not centered.
Anyhow post some pictures to enjoy your setup !!!!
I am sorry about your problem when sourcing the power to feed the screen and work the lamps, so please download the FSM and keep it handy. I never do a job or a long trip without it, just in case I need it and don't want to mess up anything.
I mounted the LCD as far forward as I could, the front of it is at the back of the sunroof. I will get some pictures very soon..
later
Bret
Here are a few pictures.. hope ya like them..
