Thanks for getting back . This may be stupid but I find the site hard to navigate? How do I post it in diesel section?Ask in the diesel section for more chance to find the trouble
forum.ih8mud.com
Hi Jim
It’s my work vehicle I have driven it every day for the last 7 years doing about 150 kilometers per day their and back. The problem occurred while driving home , I had to drive using the gears to hold the revs . I cold turn the engine off with the key so I ruled out runaway. I replaced the diaphragm as I had done this before and it had cured a similar problem before as the diaphragm had a hole in it! But no luck this time ! There is no excessive smoke , the arm travels from open to mid to closed on starting ideling and shut off, I bleed the pump of any oil build up!
I will replace the pipes now and see.
Thank you for your help ! I am new to this forum , it’s great but will take me a bit of time to learn my way around it.
Thanks
I find this rather strange ? I took another look at the butterfly valve as you suggested after replacing the two hoses .
the butterfly is set on the adjusting bolt to always be slightly open , i have never tampered with this setting and it has a lock nut to prevent it from moving with engine vibration. I reset the butterfly valve to close when ideling and the revs have come down to normal. But I now notice a nocking sound like a loose tappit . How would the butterfly have altered itself burning a run after all these years of running normally at the original setting?
