Original Intake and Exhaust Manifold
Massachusetts
Ok, hate to be needy here but here goes. i bought this 1976 40 because it was untouched original except original owner changed carb to holly and exhaust to header, deleting all smog. The good news is he gave me the original Aisin carb and everything else he had removed. I posted some pics. I think it's all there. My question is can i run that configuration without hooking up all the smog stuff for now? This all started because I was chasing a vacuum leak running the original intake manifold with a header. When I installed rebuilt aisin carb the vacuum leak reared its ugly head. Now I figure hey, lets go back to original while its apart.
California exhaust manifold (thermal reactor). :) Any cracks? It could be worth money to somebody in CA.
Don't see an air pump, emissions controller, or VSV.
You need an emissions controller, a VSV, and certain other components to control EGR and air injection. I don't recall the exact conditions without referring to the manual, but EGR for example only feeds exhaust to the engine when it's warmed-up and somewhere above idle. Air injection does not inject air into the exhaust ports during deceleration. Without the emissions controls, you have no way to control the EGR and AI and you'll have issues. I think you're probably best off solving your vacuum leak with the setup you have now, unless you have to pass emissions testing with stock components.
The intake and exhaust manifolds you can run. The thermal reactor on the truck I bought new cracked all to hell after about 15 years and I tossed it into the recycle bin. I changed over to a Federal exhaust manifold.
Air pump is still installed in engine bay. Don't know what an emissions controller or vsv looks like.
The emissions controller is a black box that is probably still in the corner of the DS footwell by your clutch foot.
This is a previous photo of a vacuum switching valve on the DS fender in the engine bay. Black box with all of the hoses. You can see the hoses hooked up to the EGR control valve and the air injection by-pass valve (two parts shown in your photo).
img_20161101_220703419-jpg.1345518
Have the vsv. Picture attached. Probably have the emissions controller. I'll check tomorrow. Question still exists, can I use the exhaust manifold and just not use all the emissions components. And if so, can I just plug ports to bypass the emissions stuff that u wouldn't install for now. I would eventually like to take this truck to where it was at factory. This truck is a try original. No rust. Never painted or cut.
Intake and exhaust manifolds you can use. They might need repair. If you have all of the emissions stuff and it all works, you can run all of it.
Those compression fittings in your fuel lines are not stock, but you can still get olives and nuts and make new lines. :)
Thanks for that. I knew about the fuel line thing. Po cut the lines to install holly and crimped return line.
Hey that looks familiar! ;) I would suggest finding a Federal spec exhaust manifold to use versus the Cali spec clunker. That manifold was built to be restrictive and heat up quickly and as such is very convuluted.
If the header doesn't leak I'd just run it versus that Cali manifold. And just fyi, it's not worth anything to CA folks with CA trucks. Some time ago they started to allow Fed spec manifolds to pass the visual smog test since these TR manifolds were as rare as hen's teeth.
I made new lines for my brothers '76 not too difficult, just time consuming...........
