OME medium springs only?
willamette/umpqua divide
got a set of previously enjoyed 2.5" mediums for a good price, can I put them in without shocks and brake lines and CC bushies or should I wait till I get all those parts as well?
any other parts recommended? panhard bar/relocate?
thanks in advance :popcorn:
...can I put them in without...brake lines...or should I wait
My only comment is that I don't think you need to do anything with brake lines on a 2.5" lift.
yup, mediums should not require any serious mods I believe.
I'm running mediums with now without any caster correction and no armor/extra weight. I haven't noticed any major wandering on the freeway, but I'm sure it would ride better with the bushings. I haven't had time to install my bushings and I don't have access to a press.
well, they're on!:D
took ~2 hours and it's way easier if you disconnect the shocks and sway bars:idea:- bunch of you guys are saying DUH... right now, but I learn slow.
First drive impression is great, I had been hitting the stops on the front going over speed bumps at even low speeds, 208K on the rig so I guess they were pretty weak. Now it feels MUCH better on the bumps, corners better, goes down the interstate just fine, steering is a tiny bit lighter if anything, no squirmy handling at speed- I do drive slow though. thanks for the deal sprocket3, I'll get your spring compressor set back asap,:cheers:
now to find a killer deal on a set of shocks....
Medium OME will lift an unmodded 80 around 2.5". That's more than enough to affect the caster. Have your caster checked and you'll find it's out of spec. Address the caster and you'll notice a positive difference in how it handles.
My shocks were completely shot after 200k miles. Not one of them would push out after they were compressed. Another note is my truck steers like crap right now. It wanders all over the road. This is how my passengers look. :eek::steer::eek:
Wait until you go on dirt roads. I just did my first "Dacar Rally" - ok work & getting from point A to point B as fast as possible on some Eastern Oregon ranch roads, no more: rattles; bottoming out; shaking to pieces; corrugated smoothness; air with soft landing on water bars. I'll probably put another 150 miles of dirt driving this weekend, then I can tighten every bolt on the 80 again. Bob
I suggest checking out Doetsch Tech Shocks - when I had my 1985 4Runner, I bought 4 14" shocks from them for $130 shipped. They were GREAT shocks! I plan on running them on my 80 when I get a lift. Here is the linky to them, and one for the other levels of shocks. I am not sure what the length is needed for a lifted 80, but many people I have read from say these are better than Rancho, and comperable to Billy's:
Doetsch Shocks and Suspension Lift and Lowering Kits
Doetsch Truck Racing Shocks and Suspensions
You might have to contact them to see the fitment for the FJ80, I can't locate any online catalogs.
John
went wheeling saturday, 150 miles round trip to get to the club meet, 0.0 handling problems (my '60 with shackles only was bad in comparison)
off road the down travel limits of the shocks kept the three wheel motion going most of the day, but did most of the run with nothing locked, even a dried out tank trap:D was no problem unlocked.
thanks for the link on shocks luv24by, any other suggestions out there? OME kits the mediums with N73 and N74E nitrochargers, those with them chime in here if you would, the shocks on the rig now are not factory, yellow paint, stickers are gone though :meh:. they have probably 100K on them so replacements are due, getting the right ones are top of the list for the '80 now.
thanks MUDders in advance for your wisdom:D
No tank trap is a problem when enough throttle is used. :hillbilly:
I'm considering going with the OME L shocks for my front. I think there's some extra travel I can get out of that. I'm going to (when I get some time) unbolt one of the shocks at the top and ramp up to see how much more travel I have.
The standard OME shocks flex just fine in the rear, I'm already rubbing on both sides when stuffed so no extra travel there.
In my experience the L's have much more effect, bang for the buck in the rear, it flexes much better than the front. With the L's ~1" of bump stop extension is needed to protect the shock, with 315's this reduces/eliminates the tire rub (depending on tire brand) and allows almost full travel of the 11+" shock.
attachment.php
I'm aware that the rear flexes more than the front, but my rear is already rubbing when stuffed while the front isn't.
From what I've seen it's the shock length that's the limiting factor in the front (currently). How much they're limiting, I don't know yet, which is why I plan on unbolting a shock and ramping up until I see the tire rub.
Are you running OME Mediums? Looks like you got 315's on there. Were you rubbing in the rear before you put on the L shocks? Bumpstop extensions? More info/pics? :cheers:
The pictured rig is my brother's, 315's, J's, L's, 2" rear bump, etc.
My first setup was 2.5" heavy, with L's in the rear, worked very well. The front flex is limited by the arms, the axle will only flex to a certain angle. In other words even with the shocks off, it doesn't want to flex, needs to be forced, if one side is allowed to droop more the other will stuff less, the axle angle remains close to the same. If your not addressing the arm flex spring rate, going to longer shocks will net little benefit on a 2.5" lift, the std OME shock is well matched to the flex.
The rear doesn't have this limitation, responds well to a longer shock allowing more droop travel. The L shock is well matched to the available travel of the rear axle. On mine, with the heavy springs never had a problem, but with the shorter mediums will probably need to retain the springs and due to having more droop, will need to address the brake line/e-brake cable/sway-bar.
attachment.php
uh......:eek:
nice flex there, I can dig that a bunch! so if I get you the standard OME N73 in the front and L shocks out back with some extended parts to allow the flex and retain the coil are about all I really need to get similar articulation. :hhmm:
gotta love this interweb thingy........
Don't forget he has J's instead of the OME Medium. 1/2"-1" of spring can make a difference.
When I compared my lift against a local mudders with J's, he got about an inch more than me. I have a body lift on top of my lift and 35's to his 33's, so my total clearance is higher, but he can *REALLY* stuff those 33's.
I don't know how much you saw of TOY350's rig since you were in the back a lot. Plus he didn't do anything really difficult, not that there was anything super hard on that run.
Anyway, if you want to compare your rig to J's and L shocks locally, take a look at TOY350's sometime.
