ome lift troubles
Egypt
i bought an fj80 4 monthe ago with the factory suspention on, then i wanted to upgrade my suspention so i got the comple set of ome suspention with an 850 heavy load infront and 863 back
and here was the results
1 . the rear diferential have shifted a bit to the right of the passenger seat
2. brakes are not working effectevly as i brake the car wouldnt stop untill it throws sideways, left or right
3. i feal car viabrations when iam over 120 km
4. the car is floting all the time and i have big troubles in controlling it when iam on the highways..
5. when i start offroading sounds comming everywhere , i think it might me the stiffness of the suspention
Anyone else have this experience ?
thanks and your feed back is appricated
First, welcome!
Secondly, you have describes exactly what happens when you install springs and shocks, and nothing else to correct the suspension geometry.
Actually, both axles will move to the side, and to fix this you need an extended pan-hard rod. Most Land cruiser shops sell them. Not sure about the Egyptian market.
2. brakes are not working effectively as i brake the car wouldn't stop untill it throws sideways, left or right
This is a 2 part issue. Part 1 is related to the above pan-hards, part 2 is the LSPV in the rear of the truck. It is a load sensing proportioning valve. You have lifted the truck, and now the brakes don't know how much fluid to send to the rear brakes. Search this forum and FAQ's and you will find your answer.
This is because the front drive shaft is at too great of a break over angle. You need to replace the front drive-shaft with a CV or Double carden drive shaft.
Your caster in your front end is now out of spec because of the lift. There are several options to fix caster for your cruiser. Search these forums and use the FAQ.
Welcome to an OME lift. Just kidding. But seriously, start searching these forums, you will find the answers to you need.
Hi!
welcome to the forum!
well, some of your symptoms are to be expected. The sideways shift when lifting for instance, because of the Panhard bar (I don't recall which way it goes in the back). Not a big problem unless it's moved a lot or you have very big tires that may rub.
The "floatation" you mention may be due to the loss of caster angle due to the lift in the front and subsequent loose steering. This can be compensated for with minor parts. Lots of discussions of this here.
The reduced braking issue could be due to the lift in the back. You want to readjust the proportioning valve in the back for that. Could be something more serious, though. Sounds a bit odd.
The vibrations of course could be the driveshaft angles.
Much of this has been analyzed extensively out there. A good search or 3 will tell you much.
It would help us help you if you could quantify how much lift you have. In the US we typically measure from the center of the wheel to the bottom of the fender (it's about 20" stock) but your fenders could well be different so your numbers may vary.
good luck
every problem you have is very common.. Here are answers for each problem you listed...
1. adjustable panhard bars (will fix it)
2. proportioning valve linkage (will fix it)
3. Drive lines (some need DC drive lines to fix it)
4. Caster is not correct, due to your lift (caster plates or drop brackets)
5. I think you are correct on this one, just a lot stiffer springs.
Good luck.
Bret
I agree with what has been said except for the dc shaft recommendations. These shafts are for specific drive angles and not a magic fix if the stock shaft has problems. It sounds like you didn't do anything for caster correction and if that is the case then a dc shaft is not going to help.
As for the noises, I'd go back and recheck the bolts and nuts. You need to make them really tight or you will get noise from them.
thank you every one your help is really appricated... and i will start working on those things .. except i have a small problem with some of the name of the things you wrote .. here in egypt we have alot diffrent name the mecanic use.. so some pic of what you said will help alot..
thanks once more for your welcoming
Do you have any extra weight on the vehicle? The 850/863 combo is designed to give around a 2"-3" lift with some weight (bumpers, sliders, etc.) If you do not have any weight, I would expect the ride to be harsh, and you to get more than the advertised lift.
The vibration and axle shift is due to the lift height, not the fact that you are using 850-863 springs. Did you replace the shocks as well? If you are within the advertised load, I bet the height will come down to what is advertised as well, and most of your vibration and other issues will go away.
I have the same lift and it rides really nice. I have a few extra pounds in the front, rear bumper and about 200# of cargo in the back. I do not have any caster correction, adjustable panhard bars, etc. It is a little twitchy, but not bad. No vibration, etc.
Before you worry to much about the driveshafts, be sure to grease the u-joints really well. That will help them with the new angle they now have to run.
The OME castor bushings are still not quite enough for the lift you have, so you are out of spec on castor. That can be fixed with castor plates available in the US, not sure about your area.
You do need to adjust the LSPV to get you brakes closer to spec.
Good luck and welcome to the forum.
Show us some pics of your rig. :cheers:
yea .. i have replaced the shocks as well , but i dont have any load in the car ,, except for the front arb bumper
so the cheap way or to start with is to put some extra pounds and see what will happen ,
and no problem ordering the castor plates
thanks
and for the sand thing mr s. carolina fz,, you are most welcome to come and see the real sand dunes ...
I have seen some real ones.. Not in egypt. Not in th US either.
I have Landtanks plates. They are the best solution for any lifted 80 series that is keeping the stock radius arms.
I think the MAF rear panhard rod drop bracket may be a better option than an adjustable rod. It puts the static (suspension at rest) angle of the panhard rod back to stock. With this there is less lateral movement of the axle as the suspension cycles than with a longer adjustable rod.
At the momement the only bolt on solution for the front is an adjustable length panhard rod.
I have not done either of the above yet and I have the longer 850J springs in the front. I dont have these problems either. It was a bit funky when initiating turns and under hard braking until I put in the caster plates.. Problem solved.
The lateral axle shift technically should be corrected. The effect on drivability if you do not is minor as compared to what happens if you dont adjust the caster after the lift.
