OME Lift Install
CO MTNS
Got my OME/Pro-Comp lift installed this weekend. I installed 850J's (used) in the front, and 863 (new) in the rear. Pro Comp ES 9000 shocks front and rear (part number 926510 w/ bushing pn 68070 for the rear eye mounts). These are 11.25" travel shocks.
Some pointers
You will need the following tools. If you don't have these buy them or pay some one else or be prepared to spend 20 hrs.
- 18 or 24" breaker bar (1/2" drive)
- 1/2" drive 17 and 14mm deep sockets
- 3/8" drive deep and regular sockets (12, 14, 17, maybe some others)
- the biggest channel locks you can buy. The kind that expand to about 4". The ones in your tool box won't work. This was the only way I could get the stud bolts off the top and bottom mounts for the front shocks (rears for that matter too)
- 6" and 10" extension bars for sockets (1/2" drive)
- 6 ton jackstands that go up to minimum 23". I ready many post that say cheap jackstands don't work. Cost isn't so much an issue as is height. They need to be tall to get the axles to drop enough tp get springs out with out needing a spring compressor.
- pb blaster
- an impact gun would be nice, but mine wouldn't turn a single bolt.
- Grease
- floor jack
- hammer (best tool for getting bushings in. don't hit the shock body)
- flat screwdriver (to get old bushings off
Getting the top bolts off for the front shocks was tough. Huge channel locks come in handy here. A pipe wrench doesn't work.
Getting the top bolts off for the shock plate in the rear will take two hours if you don't have a breaker bar and 16" of extension for the socket.
I used a stud/eye adapter for the front shocks lower mount (I think Eye mount shocks are stupid). These cost about $ from 4Wheel parts and could hold up a semi.
Liberal grease on the rear eye mounts is a good idea.
I never needed to get under my truck while it was on jack stands. This is dangerous. I losened all bolts with the wheels on the ground (or just took them out), jacked up the truck, pulled the springs, knocked off the lower mount for rear shocks, and put the springs back in. I installed the shocks with the truck sitting on the ground and bolted everything back up. Total fighting bolts and figuring out the right tools, I spent about 6 hours, maybe 7
Measurements
Pre (center of hub to fender)
front - 19.5 - both sides
rear - 20" - Both
Post
Front - 23.75 (both)
Rear - 24.25 (both)
I am midway through my front bumper fab and slider fab (can't pay attention for long) so that will likely loose me a little in the front. rear bumper fab is next. I keeping all light so I have about 60lbs in sliders 160 front bumper and winch, and the rear bumper will be about 100lbs. Measurements above are with no added weight on the truck. I will probably add about an 1" of spacer up front after the bumper/winch
Getting my caster checked tomorrow and will probably need plates.
Fabbing my own drops for rear brake line/lspv and swaybars. Cheap plate steel from home depo for brake drop and some 1" square tube for the sways. I will need to check total travel on the shocks to see if I need to drop bump stops
Pics to be posted tomorrow along with caster measurements. Makes my 33"s look small
kc
"Pics...tomorrow"?
Did you happen to document the whole process with images? Can't wait to see it.
Is liberal grease better than conservative grease? :flipoff2: Just kidding.
Now go get some 35s, you'll be much more content. No kidding. ;)
Have you driven it since? What do you think of the OME/ProComp combo?
test drive
No test drive yet. Will be tomorrow when I take it to get the caster checked. I'll definately post to comment on ride handling. I am going to try out some rough roads too to see.
Many thanks to Ebag for the procomp shock research. This saved me hours and $150.
I really want 35's but the wife is tired of the $ vacum that the land cruiser is. Next year. Truthfully, big tires make things too easy, I only found one spot I couldn't (wouldn't by myself in the middle of no where - Yoder Guclch, Colorado) drive the truck through stock locked up on 33's. Maybe my trip to moab in April will make me think different.
20 hours is a LONG time for this job. Once you have done it before and get the tricks down, shocks and springs are no more than a 4 hour job max.
One tip I share always is to do one corner at a time. If you can't get enough droop on the front corners for the new springs, use a bottle jack to get that extra. Don't unbolt the entire axle at once.
The only thing remotely hard about this is the TOP rear shock mounts. They are a real PITA to deal with. I usually trash all 4 old shocks getting them off.
Good writup, post the after shots!
Pictures of the "before and after"???:hhmm:
test drive and caster
Caster checked today pre correction
DS = -2.9
PS = -2.8
Ordering slee plates tomorrow.
Test drive:
I drove 25mi to work on an ice covered road and was convinced I was going to crash at 45 - 50mph. Never drive a vehicle with incorrect caster on an icy road. Driving home was tollerable but not for long. Managed to go 65-70 with out fear of rolling over. Caster correction is worth a few hours of work and $150
Ride: It rides amazingly well. My stock shocks were not worn out by any means at 115k, and took almost exactly the same effort to compress for removal as the new PC's did for install, yet ride is significantly improved. Damping is spot on for compression and rebound. Highway ride is smooth and controled. There are some big valley pans crossing the street in my neighborhood, that you would drag a corvettes nose on. I hit these at 25 and it sailed over them smoothly. If I tried this in our Titan or my old tundra I would have bottomed and topped out the shocks. The only qualm is that you can now tell the truck has a much higher center of gravity, roll is very well controled, but the COG is noticeable.
In short, I highly recomend the Pro Comp ES9000's. Thanks again to Ebag for the research.
Next up: Caster plates, extending my diff breathers, and likely brake lines. I need to measure total travel and see if I need bump stops dropped.
Pics, before and after, sorry none of the work. My wife was pushing me to get this done, so we could go ski.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
vibes
One more thought.
No vibes what so ever at highway speed, smooth as ever. I do get some strange GRRR'ing when turning around 90 degree corners around town and accelerating. I only get this GRRRR when on the gas around a corner, not at idle. I don't so much feel these vibes as hear them. Very slight feel at the wheel, none at the seat.
Anyone have thoughts on this? U joints? Something else?
Did I mention the OME/ProComp combo has an excellent ride. I would love an FOR lift, but I pieced this together for about 400 and may spend another 200 on brake lines and caster, making my own sway drops. So I just couldn't justify spending close to 2k.
One more thought.
Front driveshaft. With the amount of lift you have the DS isn't happy. You'll probably need to switch to a DC DS, or install a part time kit.
Test by pulling the front DS, locking the center diff, and seeing if it goes away.
dc ds vs pt
Any one want to chime in on the advantages of a pt kit vs the DC DS?
I understand that the main advantages are reduced wear on the front end and a little better power, plus the ability to slide good doughnuts for the pt kit. But I belive I loose abs? Seems like this is surefire way to get rid of front vibes. And it really doesn't cost much more than the drive shaft.
Thoughts?
It could be that the u-joints are warn, but do you think that this much lift will cause an issue with the driveline angle if the u-joints are good? I have had the same OME medium 2.5" lift installed on a 1991 and a 1993; neither one had an issue with the driveshaft, nor were there any noticeable "new" sounds, but my u-joints were in good apparent condition.
I would think that going to a P/T conversion is a bit of an extreme measure and wouldn't seem to fix the offending issue, but going with a DC shaft would always be a good idea when lifting above stock, in my opinion.
Thoughts?
I'm going with a part time kit because its actually cheaper for me than a dc shaft, with shipping to Hawaii and all...I already had my ABS disabled, so that's a non issue for me
I had brand new ujoints and it didn't help, but I'm on Js with a 1.5" spacer
