OK, what drive do we really have?
Sorry to pound a dead horse, but is it safe to say we have 1-wheel drive when CD and optional lockers aren't locked? There is drive only to the wheel with the least traction? Power will be distributed fore and/or aft as necessary through the transfer case? Then with the CD switch activated and locked, we have 2WD; power going to one front, one rear (whichever has lowest traction), right?
"technially" 2wd two wheels, 1 front 1 back it getting power. It's more of like a 60/40 split. it doesn't apply all power to one wheel.
Locke the CDL then you get a true 50/50 power distribution but still only "technically" 2WD
lock the lockers, then you have TRUE 4WD
There's a great write up on how AWD, 4WD, and lockers work in the FAQ section.
Really? :confused:....so thats the only place, huh :hhmm:
Once more: When there are differences in rotation between front and rear axles.
Make a sharp left or r.h turn and the rotation of ALL 4 TIRES WILL BE DIFFERENT.
Its a difference in rotation that a V.C sees then with friction converts temporally to lock like a LTD slip in the center diff. For that brief time its 1 front 1 rear....GOT that?
If you get into mud the wheels w/ the most traction will stop very briefly then the wheels w/ the least through mechanical force on the center diff will do the same thing as above. The VC will will say "hey that aint right!" and momentarily lock. Unless its in low which has already been covered to you. Or unless you have diff locks which has already been covered to you.
Seems to me that I've only got one tire spinning when I hit the gas on a slippery surface...but I guess there are really 2 spinning just at different speeds...one fore and one aft?
The viscous coupler will engage after a bit of wheel spin thus turning it into a 2 wheel drive. thus increasing traction. This was a feature on the 93-97 with disc brakes and full floater axle in the rear.
and by 'viscous coupler' do you mean 'transfer case'? and does that mean one rear tire and one front tire with traction?
By viscous coupler, he means the viscous coupler in the center differential, that would lead to one front wheel and one rear wheel turning.
that's how I've always considered it...thanks! And when I get the CDL switch installed, it will lock that center so that tires don't have to slip for it to grip!
it already has that. When you go into LOW RANGE, the CDL is locked. THATS what gives you a 50/50 power distribution at the t-case.
The CDL switch just allows you to do that in high as well, or with the "pin 7" mod unlock the CDL in low range.
you are still getting power right now to 1 front, 1 rear tire without any buttons. When it slips thats when it slightly changes power distribution, but all power won't go to 1 wheel in this setup.
exactly...I forgot to mention that I was talking in 'HI'...sorry about that.
when I go into 'LO', it locks the CD AND the rear so that both rear tires will turn at the same speed (and chatter on turns, etc...) along with one front tire until I lock the front...right?
Nope :frown:
Locking the CD "locks" the front and rear axles together - sending power 50/50 (or there abouts) to the front and rear axles but that has nothing to do with your rear locker. The front and rear axles still have to transmit that power to the ground and if one wheel on one of the axles is off the ground the opposite tire on that axle will spin. If both tires on the other axle have solid contact with the ground then you can probably power out of/over the obstacle. If you get one wheel lifted on both axles then you're probably not going to go anywhere.
This is where the axle lockers come in (front, rear, or both) :) but you have a separate control for those whether via the magic dial (OEM lockers) or ARBs or whatever you have/go with.
I guess it is possible for a person to set a rig up in a way that when you lock the CD that in turn triggers the rear locker to lock but that is not the way Toyota set it up and I can't see any reason anyone would do this. You'd lose control over when your rear locker locks :confused:
Bottom line....CDL and rear locker controls are separate. In OEM locked 80s in order to lock the front or rear locker the CD has to be locked first but locking the CD does not automatically lock the rear axle.
Clear as mud?
Have you read through this? --> FAQ Chapter 2 General Diffs and Difflocks for Dummies
not quite :D
In "Low" in ONLY locks the center. So it sends 50% power to the front wheels, and 50% to the rear. You can still slip and be spinning one front and one rear wheel.
The rotary "lockers" knob controls only the differentials in the axle. So once you turn on the rear locker, now both of your rear wheels are turning at the same speed. Same thing happens if you turn on the front. With both lockers on, you now have TRUE 4 WHEEL DRIVE. each wheel is turning at the same speed and can't change from the other side of the axle...so no slipping between wheels on the axle.
So if you DON"T have that rotary locker dial...you will still get slipping on the wheels.
<EDIT>>> he beat me to it :)
gotcha gotcha gotcha...I clearly have not played around with the lockers enough. SORRY! Makes sense...there are 3 actions that have to take place to have 3 things happen (or to have all 4 tires locked up)...engage 'LO' (if I don't have the CDL yet) to lock the center, then engage rear lockers to lock up the rear axle, then engage the front lockers to lock up the front axle and be all locked up. Hallelujah!
