OK, So how bad is it
Germantown, MD
Only 34K miles later
I Dont Know If Its The Picture Or The Plugs But What I See Dontllook Great
If you drive your cruiser underwater a lot, then I'd say they look fine.
If not, then you've got problems.
High oil consumption? I guess I do. If I go more than 3K miles without oil change, the oil light comes on. Some times it comes on before that 3000 miles, depending upon the weather (usually in the winter time). Truck has been running fine. I replaced these plugs 2 weeks ago with new ones.
EDIT: Forgot to mention, I do have usual oil leak. Planning on tackling the oil pans soon.
Hmm... if your leaks (pan arches, distributor ring, oil pump gasket, valve cover gasket) aren't too bad, it looks like you are burning oil pretty quickly as well.
Have you taken the valve cover off and checked your valves recently/ever? How many miles are on the truck?
149K, should be 150K this coming week. Nope, haven't checked on those valves in a long time. I do wash the bottom of the engine to clean off the oil from time to time. I guess the time has come to check on those.
Don't act solely on my advice :cool: I'm no cruiser expert, those were just my first thoughts on the issue :beer:
If that was mine I would be doing compression and leak down on all 6 cylinders.
Don't wait till the oil light goes on. Check the oil every week and add as required. Letting it get down to where the light turns on is not good for the engine
the few times my light has come on it was a quart low, not all that terrible on a 8 quart fill.
Mines been a quart low without the light.
I just think if he has a leak he should get in the habit of checking his level. Dontcha think? Now I wouldn't want to be accussed of sensoring you here as I am just giving my opinion and tonight I have laid off the crown:flipoff2:
Yes I have been doing that but there were times when I was slacking.
I have also thought of doing Compression and leak down on all 6 cylinders . But the truck has been running fairly smooth. Never had any hiccup, It does 13 to 15 MPG. Acceleration is pretty good. Only issues are the oil leaks, mostly from two places: 1)valve cover and 2) under the crank shaft pulley.
Valve cover gasket is an easy job... do it for sure.
The front main seal I've not done, but I hear the crankshaft pulley is not the most fun to remove.
I would have thought that it was running lean.
Needs to be a nice dark grey colour.
Why are people talking about valve cover gaskets and crank pulleys when they have nothing to do with this problem???
Are you adding any fuel additives/ fuel cleaners to the gas tank? Really need a closer pic of the worst plug. BTW, how much antisieze are you using if any? The plugs look very heavy with deposits.
Good point! I used BG44K pretty regularly, mostly last year and also in January this year. Not sure what you mean by antisieze. I don't think I am using any. I am just doing an oil change right now and the oil seems to look normal, like any other time. Unfortunately I threw away the plugs. I do have some blur looking closeups of the plugs. I will post'em up as soon as I can. However, the worst one is the one in the middle. It has the most white deposits and the electrode is slightly bent.
I need to check for worn valve guides and valve stem seals and/or piston rings. It seems like the plugs were the victims of the engine's condition, which was caused by the BG44K. I also used the oil additive from the dealer last year, pretty regularly.
I am curious though, these days they have 10% ethanol in the gas, could that be contributing any thing combined with the BG44K? Just wondering..
You have no impending issues but your issue is with DEPOSITS on the plug, especially that middle plug. Are you selective with the BRAND of gas you use, if so try to run somthing else. Otherwise the main cause of deposits is hardened valve seals. It's hardly worth the effort to put in new seals if you use a quart every 1k miles and it seems you're doing better than that.
As for the light it can act up over time from oil build up. Mine would sometimes come on before it was really low and when it was it wouldn't come on. I ran some Amsoil flush and Auto RX and since the light works properly. Also since the engine uses a second oil pan as a sump and has a superb crank baffle, running one quart or even two is not much to worry about.
