If I understand you, you are talking about the temp sensor adapter that threads into the 1/2-14 BSPT port on the 2F head. It has been a while since I changed out a thermal sensor, so I could be mistaken about this, but I thought that the thermal sensor had straight threads and relied on a taper to seal against the adapter. I'll have to look at an old one tomorrow. I still say that the external threads on that adapter are BSPT regardless of whether or not the internal threads are NPT or straight with a taper seal. The only difference is the five degree variation in the angle of the thread on the ½-14 pipe ports on the head. It would be very easy to run an NPT adapter into one of the ½ pipe ports on the head. I own two 2F heads for the block with domed pistons and my thread gage say that all the pipe threads on both heads are BSPT. The pipe threads on the intake manifold are also BSPT. It is difficult to determine the difference when they both have the same TPI. If you take a thread gage to the 1/8 and 3/8 pipe ports on the intake manifold they gage out as BSPT as do the adapters that mate to them. I've got two intake manifolds for a 78 and they both gage as BSPT pipe threads. The two ports on the lower thermostat housing are BSPT as are the two thermostatically controlled vacuum switches (on a 78). If all of these ports had gauged out as NPT I really would not have gone to the expense to buy the tap and dies to chase these threads to their original condition as I did engine work. Having said this, I’m not telling anyone what to do. I'm just relaying what I've discovered on my 78 and the spare parts I've reconditioned. If individuals want to use an NPT adapter or sensor on what I'm confident is a BSPT pipe port, then go for it. The chances of developing a leak at the pressures we are talking about would be very minimal.
