- Thread starter
- #21
No, no needle movement at all. New mechanical gauge will be here tomorrow, the know for sure what oil pressure is.
Hi Rudi, just wondering why the bulb flickers rather than just lights up dim or brighter as the voltage increases? Any details around that would be interesting to know.You have oil pressure because the oil pressure activates the internal Voltage Regulator that provides the working voltage for the circuit.
At low rpm you should see a slow flicker and at higher rpm the flickering increases.
Question: if you ground the gauge wire..... how much moves the needle, 1/4, 1/2, 3/4, full scale?
Warning: disconnect when the needle reaches full scale, if not you run the risk of frying the gauge (That's why there is a Voltage Regulator build in).
Do you have a analog voltmeter? What voltage do you see on the top of the sender when the engine is running?
The needle of your meter should swing between 0 and 12V, similar to the flicker from the test bulb.
Rudi
