Oil Pan Ventilation
Eagle River AK
My engine decided that the oil pan need some ventilation today....good times were not had by all
Looks like the drive shaft had a good time.
What is the drive shaft doing inside the oil pan?
Pan looks like something inside wanted out kinda bad...
Maybe. I was just guessing since the drive shaft is missing, the big dent looks drive shaft shaped and the holes seem to line up where a flopping loose or broken flange would have made the holes. The direction rotation would make holes shaped like that. Just guessing though. Waiting on the drivers explanation.
I could be wrong, but looks to me like you have the "scatter shield" bellhousing- - -very good idea to replace it when you replace the engine. The scatter shield bellhousing adapter have no way to machine align the tranny to the engine.
Maybe. I was just guessing since the drive shaft is missing, the big dent looks drive shaft shaped and the holes seem to line up where a flopping loose or broken flange would have made the holes. The direction rotation would make holes shaped like that. Just guessing though. Waiting on the drivers explanation. View attachment 1769841
no it was inside parts wanting to be outside. the oil pan had the dent when i bought it back in 2000 just never cared to replace it. what is sad is i just bought a new front driveshaft for it the day before the engine gave up the ghost
not really following this? are you saying i should get the cover for my fly wheel or that my bellhousing adapter that has been in the truck for 18+ years wont work?
It will work as it has for 18 years, but there is no machine alignment between tranny and bellhousing, you are relying on "bolt pattern alignment" which can let the tranny walk around the mounting bolts about .016". Normally this problem will (a) force the tranny input shaft to rub against one side of the input oil seal causing a leaker, and (b) cause the input shaft to wear out the crank shaft pilot bearing prematurely.
Craigslist is your friend.
I picked up my first 350 for $300. 21 years later it died and I replaced it with a lower mileage 350 for $300 with a TH350 that I didn’t need. A little time & luck and you also can find a clean 70k mile one owner motor for a song.
Now i get what you are trying to say. I will look into that when i pull the motor, what should i look for some sort of alignment pin? how will i be able to tell the difference?
maybe in the lower 48 but up here everyone thinks what they have is super special limited edition solid gold
Back in the day some parts suppliers sold Lakewood Scatter Shields for Chevota conversions, and they had no dowl pins to align tranny to bellhousing/engine. I think eventually AA or someone did make a scatter shield that did have alignment dowl pins (would have to be done on a CNC machine that could correlate engine block dowl pins to tranny dowl pins locations). This would have been for Toyota 4 speed trannys only though, the 3 speed trannys had no dowl pin alignment feature. If your's is the Toyota 4 speed tranny, I have a used/reconditioned Downey 4 speed bellhousing adapter that I am getting ready to put on the market- - -should you have any interest.
i might be, i dont think i will attack this till spring time though. Winter is fast approaching up here and my garage is not big enough to put my 40 in so she will have to wait till i either move or the weather clears up.
Not in the lower 48... up here we usually pay 2-3 times anything in the 48.
I got lucky again. Seller pulled it from a one owner ‘72 fleetside with 70k miles that he was pulling the 350 to put in a built 454 that he was converting to a short box. He wanted it gone yesterday.
