oil pan gasket????
San Jose CA
I just picked up an OEM one piece cork oil pan gasket. There are some indicator 'tits' on the inside near one end, a single on one side, a double on the other. What are they indicating? The gasket looks identical end for end, but........
Yep, what he said. I just did mine a couple months ago. Get some longer bolts so you can line-up the gasket, pan and surface before setting it inplace. Trying to hold it while setting bolts is no fun and a big PITA.
You can get gasket adhesive to hold it in place. Makes life a little less difficult
I just put one in yesterday, I found that the tabs go to the forward side of the engine. I also glued the gasket into position with fat flat washers and let it set before I sat the oil pan itself, this ensured that I got the end seals into the groove properly. After letting the sealant dry for a couple of hours, I removed the bolts and washers the screwed the pan in, putting a little more goop on the coners just to make sure. It does not leak and was an excellent fit.
I like the new one piece gasket, now that I used one.
Michael
The last one I did I think I got it from CCOT or SOR but it was like a 1/4 in thick and a mutha to get seated. Longer bolts with a washer stack up helped out to get the original bolts in and torqued up. You might need to go back and retorque to bolts again in a few days. Mine did not leak for about 2 weeks but started to dribble a little, but after retorque it stopped for good.
