Oil Pan Gasket
I charged myself a 5th of Smirnoff...mainly because I was lying on my back and had a stripped oil pan bolt (cause of my leak) needing helicoiled.
I'd guess it would have been ~$250 Colorado dollars at a shop.
If front of the engine likely to be the oil pump cover gasket, maybe $1000+
at a dealer, less at an independant shop. If at the rear likely to be the rear arch area of the upper/main oil pan, maybe about the same to reseal both pans. You should ask the mechanic what job he is quoting you and ask him the number of hours (book/billable hours).
Whatever you do, do not replace the rear crank seal without proof the leak is
coming from there (very uncommon), or just the front crank seal because
the oil pump cover gasket (next to the crank seal) is the cause the major leak 99% of time.
Can you give us more information, post up some photos?
