I must be the only retard on this forum who can't remove the damn oil filter on my Cruiser. I have a long history of bad experiences with oil filter and I'm about to set this damn thing on fire. What tool do you guys use to remove the filter? I have three different ones and I can't get access to it sufficiently to use any of them. Oil filter pliers - the arms get in the way no matter which angle I go from. Most success was from the bottom and I can grip it with the widest setting but can't squeeze it enough to move it. It crushed the filter a little and just slips. Regular old oil filter ratchet - can't get an angle to get it to grip at all. Strap wrench - no room to cinch it up to get it tight enough to grip.
I have the wheel entirely off and I can access it from there so I figured one of those caps that you place on it that allows you to use a socket to wrench it off would work - it doesn't fit tight enough on an OEM Toyota filter to get it to move. It just slips and spins.
Seriously -- I'm about to lose my mind. Any suggestions?
