I decided to do it myself after having it serviced at Toyota since purchasing my 08 used. Went to take the skid plate off and all the bolts were rusted in there. Toyota did a lube oil filter 5,000 miles prior???? I would think the bolts wouldn't have rusted that bad in 5,000 miles. I had to crank on them to get em out, broke one. Maybe the lube tech gave up on trying to find out where the filter was. I'm missing a couple bolts too from previous owner / Toyota loosing them. I will be doing all my own oil changes from now on.
A strong suggestion is to get the Fumoto valve stated in this thread. The oil comes out full stream right at the passenger tire, makes a mess.
Also being on the East Coast where salt is used, is there any product I could apply or spray on the bolts to prevent them from rusting?
Have to turn off my outdoors faucets in the winter so they won't freeze; as such, no way to rinse off after each snowfall.
(easy) to 10
, and the fact that I did this in my home garage and didnt have my right filter wrench to remove it, and had to use a pair of pliers vertically inserted into the filter cap to remove it, slowly!, plus the knuckle-dragger that did it last time must have torqued it to 48 ft/lbs, not 18......ughh, not like a 2F. Hell, I don't have to use a single tool on my 7.3L PSD, just flip the fujimoto valve and remove and install the giant filter with my bare hand.
