Offset diff/ centered output.
SLC, UT
So here is my question. I just put a TH350 and NP205 into my FJ40. I have about 23" of rear driveshaft needed if I stick with the stock axle. Of course it will be offset and the case is not. How much of a problem am I going to run into with vibration from not having a centered diff?
I have asked this question on another BB, but got no answer other than a suggestion to spend about $600 on a centered housing and axle shafts, but if I am going to do that I would just assume spend the $600 on a full floater of some type.
Have any of you ran a centered output with an offset diff, and if so is it managable? I have not built a new crossmember yet, and I have not had driveshafts made, so it is not too late to get a new axle if necessary.
I'm sure there are others that disagree, but I don't think it's that big of a deal.
The simple truth is that a driveshaft u-joint doesn't know the difference between being deflected up, down, or side to side. Angles are a bit harder to calculate (prolly best to mock it up with some scrap), but as long as the angles are within spec throughout the range of suspension travel, I say go for it.
Bad things:
Your driveshaft now is more of a target for rocks since it doesn't run directly front-rear.
You may need to get a long travel slip yoke to compensate for the greater changes in driveshaft length through the range of travel.
That is what I am thinking. If it can be balanced to the difference in up and down, why not side to side as well?
I appreciate you response, but I am still waiting to see if anyone has had any experiences with it.
Exactly. I think the lee-way is something around 5 degrees. If you are within 5 degrees both horiz and vert, I say you are just fine.
Just have to make sure those flanges are withing 5 degrees and you'll be fine, imho.....
GL,
Ragman
IMO, not a big issue for trails, but I would prefer them close on the street.
I made a rear housing...minitruck ends, cruiser center, little weld time, cheap. See my D300/700R thread for some pics. 85-older mini rear is like $100 with shafts and chunk, or $50 chunkless.
aligning it is a bitch....took quite a bit of patience, and it's off just a tad off rotationally as is, since I failed to triple check that prior to weldin' er tight.
Just in case you didn't know....the very early 40 ran the offset transfer with a centered rear differential (opposite of what you're doing). It works in a low power stock height installation.
Problem may be when you add lift (combined with the higher centerline of the 205 output), extra power, and axle wrap into the mix. These things....I know nothing about. :D
I've ran this scenario on my '63 FJ45
You should be OK. I had a 1963 FJ45SWB with a standard 3 speed t/case with the offset output, and a rare center set diff L/C axle. I would drive it at highway speeds and had no noticable driveline vibrations or u-joint failure.
I dont remember who it was I got mine from, but there was a guy in WA that made/sold centered housings.
It uses the stock LC center section, with the end flanges cut off, and replaced with the end inserts from a mini. Uses the mini axles, wheel bearings, brakes.
Advantages are:
Axles/brake/bearing parts are slightly cheaper and easier to find.
Since you are using the mini wheel bearing/brake backing plate, IIRC, you get to lose the C-clips.
I dont remember if the mini brake drums are larger or not...
E-brake is at wheels instead of the tcase.
And lastly you get the centered diff to keep everything in line...
I think I paid $250 for mine?
It also comes without the spring pads welded on, so you get to figure out exactly what angles you want for your lift and length......(IIRC, it DID come them, tho...???)
