very nice. Cant wait to hear about how it runs.
I actually got mine from SOR. It was $60 w/ the pigtail...both sides.
It installs in about an hour or so. You just need the relay, switch, fuse and however you want to install it. Went together really easily.
I haven't been able to find it on their site?Thanks Joey,
Do you happen to have to part # from SOR, perhaps on the invoice stashed next to some gold bars and stock certificates?I haven't been able to find it on their site?
...FWIW, once the head was removed we noted two cylinders showing a lean running condition. Also previously I had to do a little dash work which required the shifter be out of the park position so I just left the key on while I did the job. I know, not the best idea but it was short term. Anyway when we started the truck up afterwards it stumbled and knocked a bit and then ran smooth. Evidently with the fuel pump on the dripping injectors loaded those two cylinders enough to cause a problem. This was all before receiving the injectors back....
??? I thought the fuel pump needs engine rpm to run continuously with the ignition set to the 'on' position?
SJ
possibly, I believe I can remember hearing the pump hum before when turning the the key on but not to the start position before. Never thought you needed rpms to build fuel pressure.
That's not how the fuel pump relay circuit works, you need engine rpm *first*, ck the FSM. Residual pressure is after the key is turned off. The stumble you reference really had nothing to do with leaving the key on, read: the two cylinders weren't any more loaded, because the pump wasn't ever on?
1 drip per minute is within factory 80 spec, it sure sounds like it's possible you could have had leaking injectors, but that bad they wouldn't have passed the factory test either. Did you check them before sending them out? Interesting POR, the factory Audi 'in spec' for Bosch injectors on a 96 OBDII turbo motor running 18psi is 2 drips per minute - twice the rate at half the displacement .
Scott J
94 FZJ80 Supercharged
I submit that I could have made a hasty conclusion. Are you satisfied?
You have sinned Rick and you shall be stoned to death with ping pong balls.
-B-
You were at the very top of that list yesterday by sharing a diagnostic story that's not possible!don't start at the bottom of that list on my behalf.![]()
Hey Rick, I am thinking of getting rid of my 1FZ and putting in a Audi V6 bi turbo, can you help?
Oh really?
-B-
