Official ONSC member buying/selling thread
SRS light does not normally appear with cel
What code ? 401 and 420 are common
420 usually bad sensor or leak in system
401 is your forever friend. Could be simple or not but doesn't generally affect performance. I've had it for a year now. Time to clean the upper intake.
Listed my SM465/4sp setup in the main classads. LMK if you are interested - better price for ONSC'rs.
:beer: Ramon
https://forum.ih8mud.com/threads/feeler-sm465-custom-adapter-4sp-case-w-3-sp-gears-650.809388/
This would get someone in an FJ40 crawling real quick and cheap. I can't even guess how much I wound up in this setup getting it right, and those who have wheeled with me will tell you it works pretty well. LMK if you are interested!!!
Trying this again - $550. I had more than that in the adapter and tcase rebuild kit.
Danggit! I want it. It's a killer setup for a killer deal. It's just not in the budget right now.
I can do a payment plan for ONSC'rs :) Have done that several times already, in fact.
A friend's neighbor's house burned down about 1.5 years ago and their 87 toyota 4x4 was a victim. It's been sitting ever since. They're looking to get $600 for it. The guy said that the 22R runs although I haven't had a chance to confirm that. I went out and had a look at the body and engine compartment... I thought I might offer to get rid of the wasps and haul it away for a couple hundred. :hillbilly:
Maybe others will be interested if it could serve for parts. You can find some pictures here. If interested just PM me and I'll put you in touch with the seller.
1996 M101A3 trailer - $1200
Bought it a year ago and at the time it was just repainted with mil-spec green paint. I'm looking at getting a tow rig and trailer, which would make this M101A3 redundant. Seeing as I use it in stead of a pickup bed, I won't need it once I actually have a pickup :D
Surge brakes work great. Each wheel has an independent hand brake so that you can use the dump feature. This trailer comes with fiberglass sides and bows, with a tarp that's been repaired, but doesn't quite hold water.
Trailer has a clean NC title (in my name) and comes with a 37" H1 double-beadlock (with runflat) spare tire, which is identical to the wheels on the trailer.
Most recently we towed this trailer up to PA for CMCC and used it as a camper. We taped tulle to the top as bug netting and it was very comfortable iwht a queen-sized air mattress!! Towing to/from PA was flawless. Trailer has LED lights with new harness.
I love this trailer, but I hate redundant things, so this will go to allow me to upgrade :D
Only problem with the trailer is that I caught the drop leg on a rock while putting the trailer to work at uwharrie, bending it. Drop leg still functions normally, simply isn't straight anymore.
Pictures here. Can take more pictures at buyer's request.
https://picasaweb.google.com/108958...authkey=Gv1sRgCIPxlo7Tu-OU5AE&feat=directlink
NICE. David ... this thing is for you man.
Probably should've posted this earlier, but looking for a set of 5, 33x10.5x15's for the 40.
Also need to get a 5th wheel for the spare. Would prefer a 60 wheel to match the other 4 that I've got. Any help would be appreciated. Thanks.
-Brysen
...via IH8MUD app
-Brysen
...via IH8MUD app
I have an extra wheel if you are going to paint it. I sand blasted it and ended up not using it. It is rusted and it has been out for a while. But you can sand it and paint it and ur paint wont come off because is not chromed. Free is a good price is u want it.
...via IH8MUD app
Hi,
I'm looking for an 80 series wheel. Acorn style. I like the factory look so ok looking for one in decent quality and not painted. Let me know what you have. Oh. Also looking for. Roof basket similar to a Yakima load warrior or mega warrior.
I have a blue hub toyota fan clutch I just took off to swap to a landtank modified one... It has less than 5000 miles on it and its 3 years old. Nothing is wrong with it and it looks almost new. I just figured why not give the land tank one a try.
$35 work for someone?
Yea I need it. Where are you located?
WTB - 3 groove crank pulley with a good seal surface. Whatcha' got laying around?
:beer: R
You going to run AC in dozer?
Not now, but I want the option for compressor / Welder in the future. I have 3 groove on there now, but it's toast. Doing a little research, turns out it's a no-no to powercoat the crank pulley (aka harmonic balancer).
In desperate need of a rear driver side door for a 97 LX 450. The morons at the shop that are fixing my LX still cant find one after about 2 months. I would really like to have my LX ready by the time i get back to the states. Any leads just let me know through PM thanks.
